Can mtext command be place in a lisp loop to make
a multistring mtext editor where the user can select a group
of mtext and edit mtext strings form top text to bottem.
I have not used the mtext very much I and I am not sure how
it works. Maybe if I had a lisp routine to edit many mtext
string with one selection I would use it more.
any suggestions?
You can use the same function I posted in this thread, with one change.
Change the word TEXT to MTEXT, or if you want it to work with both, change TEXT to *TEXT as shown here:
This will loop through TEXT and/or MTEXT in the order selected.Code:(defun c:foo () (setq sset (ssget '((0 . "*TEXT"))) i 0) (repeat (sslength sset) (setq ent (ssname sset i)) (command "._ddedit" ent "") (setq i (1+ i)) ) (princ) )
