Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2006
    Jan 2007
    3
    Default can you turn a single-line into a double-line?
    complete newb here...just started with the autocad; drew a single-lined bird's eye of the exterior of a house. is there a way to make the single lines into multi-lines from this without redrawing from scratch using multi-lines? basically, convert them into double lines, or even repeat the (blocked?) shell of the house slightly smaller, leaving a specific distance between interior and exterior walls? parallelling each line and shortening each end of each line by six inches seems like it might take awhile; it's not anything close to being a mere rectangle. don't mind redrawing, but would be great to know there is a function for something like this.
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    I expect there is but I don't know how.
    If your outside shape is esentially continuous you could convert it into a POLYLINE (use PEDIT to convert a LINE to PLOYLINE) and then OFFSET by your desired amount. For parts that are not continuous you can still offset the line and <shift> FILLET to complete the corners were appropriate.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
  1. Room Tags Single Line
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 27th Sep 2006, 01:26 pm
  2. Drawing a parallel line to unknown angled existing line
    By berol in forum AutoCAD Beginners' Area
    Last Post: 29th Aug 2006, 12:06 pm
  3. Formating single line text
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 4th Aug 2006, 09:45 pm
  4. Double Line Lisp request
    By LSA in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Apr 2006, 08:54 pm
  5. Double line for multiple extrude line?
    By hyposmurf in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Jun 2004, 12:49 pm
