Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2005
    Jan 2007
    3
    Default precision please
    hello all,
    I have a problem regarding the precision in autocad '06. More precise the 6th. decimal..!
    It makes snapping and the export into 3d programs, and their snapfunctions useless.
    Is there a way to avoid this? -or maybe my settings are wrong..?
    /kristian
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    What exactly is the problem?
    AutoCAD should be more that precise for your needs.
    See: http://autodesk.blogs.com/between_th...n_autocad.html
    -and-
    http://www.intelcad.com/pages/autocad/index.htm
    Forum Newbie
    AutoCAD 2005
    Jan 2007
    3
    thank you for your quick reply...
    The problem is to snap to the corners if they are not connected on the last decimal, eventhough we only use millimeters for measures.
    And we can't figure out why! Has anybody tried this before, or is it just us..?
    Our engeneers will always go for extreme precision, that's our main concern...
    Thanks again
    /kristisn
    Full Member
    AutoCAD 2012
    Jan 2006
    England
    94
    It sounds to me like you mean you are drawing lines etc that don''t actually intersect each other because it is snapping to a defined snap point some point short of where you intended.
    My suggestion would be to turn snap off altogether in your drafting settings and use Object Snap preferences to snap to the 'end', 'intersection', 'centre' etc. of you drawing entitites. I've never understood what snap is for other than to cause this problem.
    It is possible to snap to an implied intersection - ie when lines don't actually intersect.
    Is that what you mean?
    Boro Nut
  5. #5
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,059
    Quote Originally Posted by Boro Nut View Post
    I use it all the time. If you set an appropriate snap you can speed up a lot of drawings, especially circuit diagrams and block diagrams. The biggest problem comes if you continue to use the imperial default on a metric drawing.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  6. #6
    Forum Newbie
    AutoCAD 2005
    Jan 2007
    3
    I think that could have been the problem.
    Thanks again...
    /kristian
  1. Precision problem: lines don't line up in CAD 2005
    By dott in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Dec 2006, 02:27 pm
  2. Keep units precision at default??
    By MAXXPOWER71 in forum AutoCAD General
    Last Post: 5th Oct 2006, 04:01 pm
  3. Closures with precision problems?
    By RadZilla in forum AutoCAD Drawing Management & Output
    Last Post: 17th Mar 2006, 06:37 pm
