Results 1 to 2 of 2
Thread: OSNAP troubles
    Senior Member AVITWeb's Avatar
    AutoCAD 2011
    Dec 2006
    New Jersey
    152
    Default OSNAP troubles
    Anyone see this before? In these two drawings that I have been working on, the OSNAPS will just turn off and deselect my snaps and select INSERTION. The OSNAP will often times just turn off in the middle of the command I am in....
    Stand back or I will explode ALL of the dimensions!!!
    Senior Member Seann's Avatar
    AutoCAD 2012
    Dec 2006
    Granite Bay, CA USA
    212
    The only thing i can think of is that whatever button or macro used is clearing all snaps and setting insertion as the only one. We have a lisp that does this to us as well at work so i just made an osnap button that the macro reads:
    Code:
    -osnap;end,mid,cen,int,per,qua;
    This is a transparent command that won't exit me out of the current commant I am in. You however can put in what ever snaps you use most. Hope this was a help .
  1. Undo troubles
    By Canoe2fish in forum AutoCAD Beginners' Area
    Last Post: 11th Oct 2007, 09:02 pm
  2. Layout Troubles
    By danny_macd in forum AutoCAD General
    Last Post: 17th May 2006, 04:18 pm
  3. Viewport Troubles
    By boofredlay in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2006, 02:40 pm
  4. Snapping Troubles
    By stickball23 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2006, 11:01 pm
