Results 1 to 6 of 6
    Senior Member Rooster's Avatar
    AutoCAD 2012
    Jun 2005
    234
    Default Replacing a block
    Hi. Is it possible to re-define a block and have AutoCAD only replace the block in certain layers, leaving it intact in others? I've tried this with the layers containing blocks I want to keep as they are locked, but these are updated as well. Any suggestions? If not, can you suggest a way around this?
    PS: running AutoCAD 2005
    Full Member
    Designer's Computer Details
    Mac
    MacBook Pro
    i7 2.9
    8 Gb
    750Gb
    Architectural
    Designer's Discipline Details
    Drafter
    Architectural
    AutoCAD 2013
    Nov 2006
    Portugal
    96
    The only way i know is to put a different name in the block. If you try to re-define a block all the blocks that have that name will be modify.
    AutoCAD 2012
    Jun 2005
    234
    Ok, so how do I just change the name of the ones I want redefined?
    Full Member
    Mac
    MacBook Pro
    i7 2.9
    8 Gb
    750Gb
    Architectural
    Drafter
    Architectural
    AutoCAD 2013
    Nov 2006
    Portugal
    96
    I only know one way, that gives a lot of work explode the ones you want to change the name and make them a block again with another name. Maybe someone knows a better way and faster.
  5. #5
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,071
    if there are a lot to do I would WBLOCK the ones you want to keep to a TEMP.dwg file (removing them from my current drawing). Use the RENAME command on your remaining blocks. Insert the TEMP drawing (exploded).
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  6. #6
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Try this routine, it will replace blocks (either globally or by selection).
  1. Getting Attributes for one block reference w/many block inserts?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Oct 2006, 03:38 am
  2. No block attribute entry - only block references
    By broadcastcad in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2006, 02:21 am
  3. REPLACING TEXT CHRONOLOGICALLY
    By mmcelveen in forum AutoCAD General
    Last Post: 14th Mar 2006, 05:59 pm
  4. creating block attributes without a block name
    By geordieboy in forum AutoCAD Beginners' Area
    Last Post: 19th Feb 2006, 03:49 pm
  5. Replacing Proxy texts
    By edwin in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jan 2006, 03:06 am
