Results 1 to 5 of 5
    Forum Newbie
    Land Desktop 2006
    Jan 2007
    3
    Default upside down contour labels
    On the last couple of jobs I have done the contour labels are printing out upside down, even though they look fine on the screen. When I have someone else print out the same job it comes out fine. The LABEL POSITION is set to MAKE PLAN READABLE. Any ideas?
    I use acad 2006 / ldd
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    Contours are basically polylines. A label will follow the direction of the pline segment it's on. The only ways I know to make the label appear right-side up are either to explode the contour or to redraw it in the opposite direction. Does anyone have a better way?
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    In the Contour Style Manager dialog box, under Readability, there are two settings - Make Plan Readable and Label Positive Slope. Perhaps they are set differently in the different plots.
    The Contour label alignment does have significance to those who know. The top of the text should be uphill, so when you are looking at the plan with the labels the right way up, you know you are looking uphill. Only one label on one contour is needed to discover uphill.
    Full Member
    not specified
    May 2005
    70
    If you have to end up reversing the direction of a polyline/contour you could use the lsp below:
    ;;; RPL.LSP a program to reverse the direction of polylines
    ;;; Program by Tony Hotchkiss. Enter RPL to start the program.
    (prompt
    "\nType RPL to run command."
    (defun c:rpl ()
    (setq again nil)
    (setq p-ent nil)
    (prompt "\nSelect a polyline: ")
    (while (not p-ent)
    (setq p-ent (car (entsel)))
    (if (not p-ent)
    (prompt
    "\nNo object selected; select again: "
    ) ;_ end of prompt
    (if (and (/= (dxf 0 p-ent) "POLYLINE")
    (/= (dxf 0 p-ent) "LWPOLYLINE")
    ) ;_ end of and
    (prompt "\nNot a polyline, select again:"
    ) ;_ end of prompt
    (setq p-ent nil)
    ) ; progn
    ) ;_ end of if
    ) ;_ end of progn
    ) ;_ end of if
    ) ;_ end of while
    (setq etype (dxf 0 p-ent)
    x-ent p-ent
    is-closed (dxf 70 p-ent)
    ) ; setq
    (if (= etype "LWPOLYLINE")
    (setq num-vert (dxf 90 p-ent)
    elist (entget p-ent)
    elist (member (assoc 10 elist) elist)
    vvlist nil
    ) ; setq
    (repeat num-vert
    (setq vlist (list (cdr (assoc 10 elist))))
    (setq vlist
    (append vlist
    (list (cdr (assoc 42 elist)))
    ) ;_ end of append
    ) ;_ end of setq
    (setq vvlist (append vvlist
    (list vlist)
    ) ;_ end of append
    ) ;_ end of setq
    (setq elist (cdr elist)
    ) ; setq
    ) ; repeat
    ) ; progn lwpolyline
    (setq vvlist nil
    p-ent (entnext p-ent)
    ) ; setq
    (while (/= "SEQEND"
    (cdr
    (assoc 0 (entget p-ent))
    ) ;_ end of cdr
    ) ;_ end of /=
    (setq vlist (list (dxf 10 p-ent)))
    (setq vlist (append vlist
    (list (dxf 42 p-ent))
    ) ;_ end of append
    ) ;_ end of setq
    (list vlist)
    ) ;_ end of append
    ) ;_ end of setq
    (setq p-ent (entnext p-ent))
    ) ; while
    ) ; progn polyline
    ) ; if
    (setq p-list (mapcar 'car vvlist)
    p-list (reverse p-list)
    b-list (mapcar 'cadr vvlist)
    b-list (reverse b-list)
    b-first (car b-list)
    b-list (cdr b-list)
    b-list (append b-list (list b-first))
    b-list (mapcar '- b-list)
    ) ; setq
    (setq enlist (list '(0 . "LWPOLYLINE")
    '(100 . "AcDbEntity")
    '(100 . "AcDbPolyline")
    (cons 90 (length p-list))
    (cons 70 (dxf 70 x-ent))
    (cons 8 (dxf 8 x-ent))
    ) ; list
    ) ; setq
    (setq elst nil)
    (repeat (length p-list)
    (setq
    elst (append elst
    (list (cons 10 (car p-list)))
    ) ;_ end of append
    ) ; setq
    (setq
    elst (append elst
    (list (cons 42 (car b-list)))
    ) ;_ end of append
    ) ; setq
    (setq p-list (cdr p-list))
    (setq b-list (cdr b-list))
    ) ; repeat
    (setq enlist (append enlist elst))
    (entdel x-ent)
    (entmake enlist)
    (prompt "\nPolyline direction is reversed.\n ")
    ) ; rpl
    (defun dxf (code ename)
    (cdr (assoc code (entget ename)))
    ) ;_ end of dxf
  5. #5
    Forum Newbie
    Civil 3D 2005
    Sep 2008
    1
    Default Upside down contour labels
    Have you had any more suggestions since your original posting?
    Apparently the message is - just live with it even though one tries to be meticulous?
    Quote Originally Posted by surveyor View Post
  1. LABELS TUTORIAL
    By /\/lg|-|T/\/\@R3 in forum Civil 3D & LDD
    Last Post: 4th Mar 2007, 05:45 pm
  2. tile labels in .DCL files
    By ancisai in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Oct 2006, 05:07 am
  3. Misc: Interesting Presentation "Turning Email Upside Down" HMTP
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 8th Oct 2006, 07:32 am
  4. Contour curves to DWG mesh.
    By jmansa in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Sep 2005, 08:54 am
  5. Database labels formating
    By bruno.trudo in forum Autodesk Software General
    Last Post: 25th Feb 2005, 06:41 pm
