Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Error
    Junior Member Alasdair's Avatar
    AutoCAD LT 2007
    Sep 2005
    Leamington Spa England
    22
    Default Error
    Using AutoCAD 2007LT I keep getting the following error message
    Unhandled eo6d7363h Exception at 7c812a5bh the programme then shuts down. Can anybody help or direct me to some help. Thanks in antisipation.
    From the seeds of any adversity comes forth an equal or better oportunity. Life is not a rehearsel. How to become a boring person with two statements.
    Senior Member
    Architectural DT 2007
    Aug 2006
    Midwest
    218
    What were you doing when that happened? (not that it always makes a difference)
    AutoCAD LT 2007
    Sep 2005
    22
    Just opened 2007LT moved curser to File it then shuts down
    Senior Member Norts's Avatar
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    here is what Google comes up with:
    http://www.google.co.uk/search?q=Unh...ient=firefox-a
    a tip for the future is to first search this site, then search google
    Posting no more
  5. #5
    AutoCAD LT 2007
    Sep 2005
    22
    Thanks for the help. Followed the instructions for a clean install. Removed all Acad programmes and then did a complete re-install. So-far I am not getting the error message. I would love to know what caused it. If its now working with a clean install what would have caused the error I suppose I will never know LOL. Thanks again. Keeping everthing crossed LOL
  6. #6
    AutoCAD LT 2007
    Sep 2005
    22
    Quote Originally Posted by Norts View Post
    Found the help files very useful. I am concerned about intalling the Service Patch 1 for 2007 LT could this cause any problems.
  7. #7
    Senior Member
    Aug 2006
    Midwest
    218
    Yes, service pack installs COULD have the potential to create problems, but the whole point of a service pack it to correct existing problems, so it should be alright. I have installed it on mine, and no problems over here.
  8. #8
    AutoCAD LT 2007
    Sep 2005
    22
    Quote Originally Posted by pennylove View Post
    WELL I am getting totally pi--sed off I have done a complete removal of all Autodesk products rebooted removed from registry Autodesk references so machine is clean, checked othat no running programmes reinstalled 2007LT and then Service Pack 1 Start programme after about 5min move curser to File and same fatal error occures. The only programme that seems to work OK is 2004LT so I have had to reinstall 2004LT to get a working programme. I have now tried everthing other than rebuilding my PC. I wonder if anybody out there has any more suggestions.
  9. #9
    Senior Member
    Aug 2006
    Midwest
    218
    Sounds like it's time to call autodesk, or your reseller.
  10. #10
    AutoCAD LT 2007
    Sep 2005
    22
    This is the point where I am drowing in anger. I purchased 2007Lt in the UK about 7 months ago as an upgrade to 2006 LT I did not take out a subscription so retailer is not interested. Autodesk just tell me to contact the retailer as they do not give support ??????
  1. Help: ARX ERROR
    By StykFacE in forum AutoCAD Drawing Management & Output
    Last Post: 26th Feb 2007, 05:09 pm
  2. ARX-Error
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2007, 06:17 pm
  3. Replies: 0
    Last Post: 2nd Nov 2006, 11:51 pm
  4. Replies: 0
    Last Post: 19th Oct 2006, 12:00 am
  5. ARX error
    By wadep in forum AutoCAD Drawing Management & Output
    Last Post: 13th Aug 2006, 05:06 pm
