Results 1 to 7 of 7
    Senior Member Cadastrophic's Avatar
    not specified
    Dec 2002
    Australia
    152
    Default 3D Perspective view.
    I was sent two macro scripts recently, with the object of turning on the perspective view and then the parallel view.
    I made the respective buttons and entered the macros, but when I went to use them, neither worked.
    Would one of you kind people in the know please cast your eye over the scripts and see if you can spot where they go wrong?
    Thanks in advance.
    Perspective on:
    $M=$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(ge tvar,cvport),1)),'_3DXProjection,'_3DXProjection _S)
    Parallel on:
    $M=$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(ge tvar,cvport),1)),'_3DXProjection,'_3DXProjection _P)
    I'm sure you said "Hurry up and DELETE your work".
    AutoCAD 2004, Inventor 8.
    AMD Athlon 64 FX-55, 3GB RAM, NVIDIA Quadro4 980XGL, Windows XP Pro.
    Flores
    What version of ACAD are you using? in 2000i, "3DXProjection" is not a command.
    Flores
    not specified
    Dec 2002
    Australia
    152
    Oops! Should have mentioned I use AutoCAD2000.
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    It's not a command in 2000 either. Must be someone 3rd party app. -David
    R12 (Dos) - A2K
  5. #5
    not specified
    Dec 2002
    Australia
    152
    Bummer! OK, if that's the case, does anyone have a macro for Parallel and Perspective please?
  6. #6
    Flores
    Well, it's not really that hard to get to parallel or perspective. Either enter "3do" at the command line, or click the "3D Orbit" button, right-click the mouse, then in the right-click menu you will find projection, parallel or perspective.
    Flores
  7. #7
    not specified
    Dec 2002
    Australia
    152
    Thanks for the replies. Yes, I suppose it's not the end of the world to access the routine that way. I'm just a very button oriented worker.
