Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    Building Systems 2006
    Jan 2006
    Scotland
    48
    Default Make my DWG read only?
    Is it possible to make a read-only CAD drawing? I want to make a symbols library where people can copy and paste symbols into there own DWG, but cannot edit the drawing?
    cheers in advance.
    Senior Member craigp's Avatar
    AutoCAD 2007
    Jun 2005
    North Lincs, England
    346
    I think you could right click on the drawing file icon (once saved), go to properties and tick read only?
    Leaving the world of AutoCAD and 3DS MAX for Solidworks
    Full Member
    Jan 2006
    Scotland
    48
    Quote Originally Posted by craigp View Post
    aaahh! So obvious. I was trying to do it from within CAD.
    Thanks!
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    well that doesn't "lock" the drawing or anything. they can still edit it, do a Save As, or simply uncheck the Read Only option for the file once they have it.
    is this "file" on a network or are you sending it to someone else via email?
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  5. #5
    Full Member
    Jan 2006
    Scotland
    48
    Quote Originally Posted by StykFacE View Post
    It will be on a network.
    I'd prefer that it couldn't be edited at all, so nobody can uncheck read-only and add there own symbols, but if it's not possible that will have to suffice.
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    might want to get with your IT guy to set up a directory on the network that has READ capabilites but not WRITE capabilities. that way it'll never be altered, and the file can still be used for Inserting blocks.
  7. #7
    Full Member
    Jan 2006
    Scotland
    48
    Hmm I'll look into that - good advice..
  8. #8
    Full Member
    Jan 2006
    Scotland
    48
    sorry, repost
  9. #9
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,511
    Ideally, each user will belong to the proper group.
    For example you may belong to a group called "CAD" and the other people belong to a group called "NOCAD".
    CAD members would have "WRITE" access and NOCAD members would NOT have write access.
    R.K. McSwain
    CAD Panacea | twitter
  10. #10
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Keep a copy of your blocks for just in case. Now explode your block and recreate it -but this time uncheck the ALLOW EXPLODING in the block definition window. Process all the blocks one by one and publish this "non explodable" form.
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  1. Please Read This Before Posting
    By CADTutor in forum AutoCAD General
    Last Post: 13th Feb 2008, 10:10 pm
  2. Read only
    By kellzoo in forum AutoCAD General
    Last Post: 22nd Jun 2006, 01:25 pm
  3. Is it possible to make a read-only sysvar a read/write var?
    By whatispunk in forum AutoCAD General
    Last Post: 11th Mar 2006, 11:49 am
  4. Read-only in 2005
    By laurenb in forum AutoCAD Drawing Management & Output
    Last Post: 16th Feb 2006, 04:04 pm
  5. Help! no more read only files
    By HUEB in forum AutoCAD Drawing Management & Output
    Last Post: 20th Apr 2005, 02:55 pm
