Results 1 to 5 of 5
Thread: menu troubles
    Forum Newbie
    Land Desktop 2007
    Feb 2007
    3
    Default menu troubles
    How can i customize my menu palete? everytime I want to create a profile or cross sections i have to leave my workspace and go into civil design to access these menus and i can figure out how to put them in my custome workspace. I am running a-cad 2007. Thanks in advance for any help you might can offer.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Can it be done using Profiles?
    Forum Newbie
    Land Desktop 2007
    Feb 2007
    3
    No, it's done by workspaces in 2007 version. I can situate the tools but I cant figure out how to switch the menus over
    Junior Member
    AutoCAD 2007
    Feb 2007
    20
    Hi
    Have you tried using the transfer option in the Customise menu?
    Right click on a tool bar and go down to the bottom to select customise.
    Select the transfer tab at the top.
    Without knowing exactly how yours is set up, I cant tell you exactly what your need to do, but here you can transfer menus and toolbars from one .cui file to another.
    Basically, you need to have the 'civil design' .cui file in one half and your workspace in the other, then you simply drag the menu item you want into the menu section under your workspace.
    Click 'OK' then that menu should added to your workspace.
    Hope this helps.
    Dave G
  5. #5
    Forum Newbie
    Land Desktop 2007
    Feb 2007
    3
    i finally got it. just in case someone else has this problem i'll run through it. 1. pull down the workspace tab. 2. select customize at the bottom. 3.select the workspace you want to customize and click costumize workspace. 4.scroll to the bottom of the window on the left and click on partial cui files. from there you can open the different workspaces and check the items that you want.
    I appreciate the help, and I hope this comes to some use for someone.
  1. Undo troubles
    By Canoe2fish in forum AutoCAD Beginners' Area
    Last Post: 11th Oct 2007, 09:02 pm
  2. OSNAP troubles
    By AVITWeb in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2007, 06:08 am
  3. Viewport Troubles
    By boofredlay in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2006, 02:40 pm
  4. Snapping Troubles
    By stickball23 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2006, 11:01 pm
