Look into the FILLET command on POLYLINES. Splines do not have squares vertices. -David
I'm trying to draw some figure which has a lot of square AND round vertexes. When I use Polyline, I can only the square vertexes in a easy way. I could use the arc option in Polyline for the round pieces but I it's a lot of work.
When I use the Spline command, I can draw the round pieces of the figure
very easy and fast, but I can't draw the square vertexes.
Can somebody explain me how to draw this kind of figures?
R12 (Dos) - A2K
The fillet command is not right for the kind of figures I need to draw.Originally Posted by David Bethel
The round vertices I need to draw vary in all kinds of ways.
I need something like the Pen option in Adobe illustrator.
Maybe I could draw the figure in Adobe Illustrator and export it to Autocad, but I think it's easier if I could draw the figure in Autocad itself.
Well there is always the SKETCH command. You could then PEDIT it together and the SPLINE the polyline. -David
R12 (Dos) - A2K
Polylines draw as 3DPOLY can give the benefits of both polylines and splines.
Nick
http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
http://s240.photobucket.com/albums/ff241/dyNick_Scots/
http://designgraphicsshowcase.blogspot.com/
High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
Home - AMD 2.1GHZ - 512Ram, 64 Video,
Laptop Inventor 7, Autocad 2004, Corel 11
Okay thanks I will try this out.
