Ricardo,
This has just been answered in the Autocvad General area. Check there for an answer.
How can I open a .plt file? I can't find it anywhere on CAD.
Failure Is A Far Greater Teacher Than Success
Ricardo,
Open it to do what, view it?
See: http://cadpanacea.com/node/28
Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
http://caddstudio.blogspot.com/
PLT2DWG only translates Plot files that are in HPGL format.
"Work Smart, Not Hard"
Portfolio ( Updated 03/14/10 ): http://www.rdeweese.com/
Disclaimer: The views expressed in the above post are just my own opinions. Take them with a grain of salt
I'm not trying to step on toes here, I was merely expanding upon what you had posted. You didn't mention why it only translates certain ones, so I thought it was worth mentioning. I apologize if you took offense. By all means, give it a try, but if it doesn't work, it's because it's not HPGL format.
We use Oce Repro Desk to open the .plt files before we send them to the printing company to make sure they're correct. This is VIEWING ONLY! If there are changes that need to be made, the .plt file needs to be re-made thru AutoCAD.
AutoCAD 2005
ADT 2005
OCE for hpgl2 yup
