Results 1 to 3 of 3
    Junior Member
    not specified
    Apr 2006
    Arkansas
    13
    Default Chordal Tolerance/Triangular Deviation
    At my workplace, we draw small 3D positives in AutoCAD and have SLA positives made. From these SLA positives, we make silicone molds. Anyhow, the SLA company sent an e-mail and I can't figure out how to adjust what they are saying. """ I have attached a JPEG File depicting coarse features in your files; due to the fact the parts are not large this will be not pose a problem, but as the parts get larger the surface coarseness is more noticeable. You can increase your surface resolution by increasing your setting for chordal tolerance height or it may be called triangular deviation to 0.001 inch when the STL file is exported from your CAD program """. Anyone familiar with the Chordal Tolerance settings? How about Triangular deviation? A co-worker who draws most of these positives can not find these settings in AutoCAD and we need help. Any assistance would be appreciated.
    Brian
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    “Chordal Tolerance numerically describes the maximum distance between the actual part surface and the tessellated surface of the STL file.”
    Referenced from: http://fstroj.utc.sk/journal/engl/papers/036_2002.pdf
    It sounds like you may have to increase the default values on such parameters as isolines, surftab1, surftab2, etc. to get the desired result the SLA company is seeking.
    I too could not find any reference to chordal tolerance or triangular deviation within AutoCAD.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Addendum:
    This might help too:
    < start quote>
    DISPSILH
    Show Silhouettes in Wireframe
    Controls whether silhouette curves of 3D solid objects are displayed as wireframes. This option also controls whether mesh is drawn or suppressed when a 3D solid object is hidden. This setting is saved in the drawing. Clear this option to optimize performance.
    The value is also controlled by the DISPSILH system variable.
    ISOLINES
    Contour Lines per Surface
    Sets the number of contour lines per surface on objects. A higher number decreases display performance and increases rendering time. The valid range is 0 to 2047. The default setting is 4. This setting is saved in the drawing.
    The value is also controlled by the ISOLINES system variable.
    <end quote>
    The above comes courtesy of AutoDesk Discussion Groups.
    Last edited by ReMark; 8th Feb 2007 at 12:29 pm. Reason: sloppy copy/paste technique...my apologies
  1. TOLERANCE
    By sentinel in forum AutoCAD Beginners' Area
    Last Post: 16th Feb 2010, 04:05 pm
  2. Need someone to explain to me tolerance
    By m_m_m35 in forum AutoCAD Beginners' Area
    Last Post: 28th Apr 2005, 01:12 pm
