Results 1 to 5 of 5
    Full Member irelandmc's Avatar
    irelandmc's Computer Details
    XP Pro 32 bit
    Thinkpad T420
    Electrical
    irelandmc's Discipline Details
    Engineer
    Electrical
    Manufacturing sector, lean sigma continuous improvement specialist.
    AutoCAD 2005
    Feb 2006
    US - IA
    48
    Default Cannot select viewport in layouts
    I'm stumped- After creating a viewport in a layout, I can no longer select it. This appears to only be true with viewports on the def-points layer. I've created a new non-printing layer to put my viewports on (just make sure that this would work), but now I will have to re-construct all of my layouts because I cannot edit the current ones!
    I CAN work around it, but I would PREFER to fix it. It's just this one drawing that is doing it (of course the one with dozens of layouts).
    I closed and re-opened- no improvement.
    Does anyone know why I cannot edit viewports on the defpoints layer?
    Always ahead...
    AutoCAD 2005
    Previously AutoCAD LT 2006
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Try thawing/turning on layer 0.
    Senior Member Norts's Avatar
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    IF your viewport is on layer Defpoints AND you are unable to select it, my first suspicion would be that your 0 (zero) layer is switched off. IF this is the case, just switch layer 0 (zero) back on, and the viewport should now be selectable again.
    Posting no more
    XP Pro 32 bit
    Thinkpad T420
    Electrical
    Engineer
    Electrical
    AutoCAD 2005
    Feb 2006
    US - IA
    48
    That was it. Thank you.
    Any knowledge about why this happens when 0 is frozen?
    Always ahead...
    AutoCAD 2005
  5. #5
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    defpoints is a specific layer for Definition Points (nodes). this layer i believe is associated directly to layer 0. i think anyways....
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  1. Replies: 2
    Last Post: 14th Jul 2006, 05:24 pm
  2. Selecting a viewport within a bigger viewport
    By edwin in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2005, 06:13 pm
  3. layouts
    By PRS in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2005, 12:44 am
  4. \\layouts//
    By randomBullets in forum AutoCAD General
    Last Post: 29th Jul 2005, 02:41 pm
  5. Using layouts
    By careyc in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jun 2005, 06:45 am
