gitfiddler Posted February 9, 2007 Share Posted February 9, 2007 For some reason, I can't find my Command Line Window. It somehow became undocked and is no where to be found on my screen. It does not appear to be floating anywhere. I've gone through all my display settings; however it says that it should be there and show 3 lines of commands. Any suggestions? thanks. Quote Link to comment Share on other sites More sharing options...
architecture68-raff Posted February 9, 2007 Share Posted February 9, 2007 Sometimes changing you screen resolution in your monitor settings, and then changing it back to your correct resolution can force the command line back into view Quote Link to comment Share on other sites More sharing options...
gitfiddler Posted February 9, 2007 Author Share Posted February 9, 2007 dang, it didn't work. Thanks for the suggestion though. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 9, 2007 Share Posted February 9, 2007 For some reason, I can't find my Command Line Window. It somehow became undocked and is no where to be found on my screen. It does not appear to be floating anywhere. I've gone through all my display settings; however it says that it should be there and show 3 lines of commands. Any suggestions? thanks. What AutoCAD version? Take a look at: http://cadpanacea.com/node/9 and http://cadpanacea.com/node/29 Quote Link to comment Share on other sites More sharing options...
gitfiddler Posted February 9, 2007 Author Share Posted February 9, 2007 I'm running architectural desktop/2002. I'm going to try the suggestions from dotsoft.com. I'll let you know how it turns out. You never realize how much you use the little thing until you loose it! Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 9, 2007 Share Posted February 9, 2007 I'm running architectural desktop/2002. I'm going to try the suggestions from dotsoft.com. That should work. I remember using that a few times to fix this problem. Quote Link to comment Share on other sites More sharing options...
gitfiddler Posted February 9, 2007 Author Share Posted February 9, 2007 Thank you, thank you, thank you! I was able to change it through registry edit. This is a great forum, I happy I found it. I'll be sure to keep checking it daily. Thanks again! Quote Link to comment Share on other sites More sharing options...
Seann Posted February 9, 2007 Share Posted February 9, 2007 Don't worry about getting addicted to it or anything.......105+ posts later in 2 months or anything is addictive right.......right? Quote Link to comment Share on other sites More sharing options...
artech Posted February 22, 2008 Share Posted February 22, 2008 try using control+9 to unhide the command line window Quote Link to comment Share on other sites More sharing options...
NaeKid Posted February 22, 2008 Share Posted February 22, 2008 Another option is to get the "list" window open by hitting F2 and you can resize it to whatever you like. Quote Link to comment Share on other sites More sharing options...
wenxu Posted June 14, 2012 Share Posted June 14, 2012 This is what I want. Quote Link to comment Share on other sites More sharing options...
