any reason why my posts keep getting shunted to the end of page/s ??
Fail to Plan, Plan to Fail.
DropBox | finding the light...
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
In settings>general settings, you have the option to show oldest first or newest first. So, the reason you get shunted to end of page is per your settings.![]()
An honest mistake at the worst, an excellent learning opportunity at the best.![]()
oh yes and due to the time difference in NZ - being ahead of you...it would jump a few times...(that is what i was questioning cos you guys would post and i would keep moving down...so that answers it....thanks (didnt have to growl..SLW210..it was an honest question...altho i detect sarcasm because I was growling..hmmm)![]()
When my work laptop got upgraded I got Windows 7 Pro & AutoCAD 2010. From day one I had issues with the cursor jumping across the screen for the slightest movements. After numerous calls to our tech support and calling my favorite CAD Professionals, I finally found an article at:
http://usa.autodesk.com/adsk/servlet...linkID=9240617
Which explains how to Enable Hardware Acceleration through the 3DCONFIG command.
Matthew Perreault
Hi,
If you have a viewport and you want different copies scaled proportionally...
my turn ...
command:SAVEALL
this works well when you have 2 or more opened drawings as you only need to type once and ALL your opened drawings will be saved.
note; read only files will prompt you for location
command:CLOSEALL
similar to above but this time it will closed "duh" all opened drawings.
note: unsaved/ modified files will prompt you to save them prior
- i usually use this 2 command one after the other to max its usefulness
command:SAVE
unlike "saveas" this one will save a copy of your drawing without exiting the current one you are trying to save
hope that helps![]()
I just found this out a couple of weeks ago myself!
Want to toggle variables that have "on/off" (or "1/0") settings but can't find a way to do it without an IF statement (or COND in LISP)?
For AutoCAD LT, use Diesel:
For those with LISP capability it's only slightly different:Code:^C^Cvarname $M=$(- 1 $(getvar varname))
These are very useful in ribbon buttons.Code:(setvar "varname" (- 1 (getvar "varname")))![]()
