Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    Super Member MaxwellEdison's Avatar
    MaxwellEdison's Computer Details
    Win 7 (64-bit)
    HP h8-1070t
    Intel Core i72600
    12GB
    AMD Radeon HD 6850
    Dell 20" LCD Widescreen (Main) NEC Accusync 125F 20" CRT (Secondary)
    Architecture 2012
    Dec 2008
    Lebanon, PA
    749
    I have invented a new type of wheel constructed of dead horses, thus solving the problem once and for all.
    Just because you're , doesn't mean wrong is all that's .
  2. #22
    Senior Member GypsyQueen's Avatar
    GypsyQueen's Computer Details
    Windows XP
    Dell Precision T3400
    Intel Core 2 Quad Q6600 @ 2.40 GHz
    2 GB RAM
    NVIDIA Quadro FX570
    Dell 2208 WFP 27"
    MEP 2011
    May 2008
    Corpus Christi, Texas
    114
    Quote Originally Posted by MaxwellEdison View Post
    I don't think I want to comment on that.
    "Yes, this is my natural font. Quit staring" - Maxwell Edison offered this up for me and I love it!
  3. #23
    Forum Newbie
    Electrical 2008
    Oct 2009
    1
    Laughing Reduce Fil Size
    FILTERS Command is working very good
    Thank U....rkmcswain
  4. #24
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    Quote Originally Posted by nisman View Post
    Hi all,
    I was drawing isometric dwgs and the file keep pn getting bigger and eventually it became 78,000KB for an iso. Is there a way to reduce the size beside exporting dxf file. Normally an iso should be average a few hundred KB only. Hope someone can help. Thanks
    Gee, I only wish I could get one that small right off. Many of my files are of the 100+K range to 400+ range lately. They reduce in size fast once you open them up and do a save or SAVE-AS function. That fast step there knocks off about 75% of the file size. If you SAVE-as an earlier versionthat what you got as it will often knock off lottsa K for you, long as everything is there once you get done.
    Wm.
  5. #25
    Senior Member Cadologist's Avatar
    Cadologist's Computer Details
    Windows 7 Professional
    Hewlett-Packard Z420 Workstation
    POS Fisherprice Beta Nukemaster v2.6
    Intel Xeon CPU E5-1620 v2 @ 3.70Ghz
    16 GB
    Nvidia Quadro K2000
    Three Hamsters, Alumimum Wheel
    Busted up 1970's 'Vintage Green' File Cabinet
    Dual Monitors (24" LG LCD)
    Multi-disciplinary
    Cadologist's Discipline Details
    Corporate CAD Development
    Multi-disciplinary
    AutoCAD 2015
    Oct 2009
    Canada
    136
    Yeah it seems all newer versions reduce the file size, or so it seems as I recall it being mentioned in several release summaries. Overkill (as mentioned) works well as it deletes linework overtop of linework (copies) but I am always cautious with that command and (on a big drawing, it takes a TON of time to run) and might not really clean much up and it re-creates polylines and other things which could hamper your design by changing entities away from what you intended (like endpoints being endpoints and whatnot). Example, you may have two lines the same, on top of eachother and need both of them for various reasons, OVERKILL will remove one of them so some thought into your drawing style should be addressed before running that command.
  6. #26
    Senior Member JerryG's Avatar
    JerryG's Computer Details
    Never Good Enough
    My head
    Notebook
    Its big
    Civil
    JerryG's Discipline Details
    Stream Restoration
    Civil
    Civil 3D 2015
    Jan 2008
    Washington State
    418
    Good point Cadologist.
    That could be scary when you have a Datum Line and Surface line - different
    Z value but one over the other for volume calcs.
    Never trust a computer you can't throw out a window!
  7. #27
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    I do a lot of intaking of DXF files here. Finding that there are numerous ways of softwares to define same line. Usually depends upon how wide original was.
    If I ERASE a former DXF area off, I find out then that little area may have contained 4000+ little bitty lines. Boy does that reduce the K size then. Eventially I get to a situation where only the most modern ACAD lines are present. That is about small as can go there.
    Wm.
  8. #28
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Let Us Purge!
    Audit.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  9. #29
    Junior Member
    AutoCAD 2005
    Oct 2008
    13
    yes you can purge
  10. #30
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    Quote Originally Posted by ttsadaf View Post
    yes you can purge
    Well, using the PURGE command will certainly reduce the overall size to the file, it is not a magic button either. Using the command will eliminate a few riding along file types, layers, linetypes, and fonts, it will not eliminate a few of the unused types in the array, which tend to hang on for no apparent reason. Your default layer, linetype or font will not be removed from the list via a PURGE. They tend to ride on, and on. Even if zero is upon that layer.
    I do not know the criteria as to what is chosen to be purged out, but someone here may have a better explaination. But, I do like the idea that one file is small enough it can be written to a 1.44M floppy disk, then handed away to another user, and they can then transferr and see your work.
    The use of PURGE may or may NOT reduce teh size to the file, depending upon how many times it was used.
    Wm.
