Results 1 to 3 of 3
    Junior Member
    AutoCAD 2007
    Jan 2007
    10
    Default How do i get sections
    Hey Guys
    Using the sheet set manager, i have worked out how to use named views to show elevations that update from the original (because they are xref'ed) with the call out blocks and block labels, but i can't work out how to do the same for sections. Is there a way to do this and have the sections update with a reload of the x ref just like the elevations do ?
    I am using ACAD 2007
    thanks
    Junior Member
    AutoCAD 2007
    Jan 2007
    10
    Is this possible guys?
    Junior Member
    AutoCAD 2007
    Jan 2007
    10
    Well after some mucking around i figured it out. you can do it so its all good.
  1. Cross sections
    By LEIGH in forum AutoCAD General
    Last Post: 22nd Jul 2012, 02:09 pm
  2. Cutting out 2D sections
    By gib65 in forum AutoCAD Beginners' Area
    Last Post: 23rd May 2006, 04:32 am
  3. sections through a building
    By c_murds in forum AutoCAD General
    Last Post: 6th Dec 2005, 01:54 pm
  4. Drawing sections
    By red00028 in forum AutoCAD General
    Last Post: 30th Nov 2005, 10:04 am
  5. surface sections
    By leptogenesis in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th May 2005, 08:13 pm
