Results 1 to 4 of 4
    Full Member
    AutoCAD 2013
    Nov 2006
    Perth, Australia
    89
    Default Change Order Of Plotters
    Hello There,
    When I go to the plot dialogue box, there is a list of different plotters listed. Is there a way to change the order of these, as I would like the ones I use most to appear together, so I don't have to scroll through them each time.
    Thanks
    Full Member
    Designer's Computer Details
    Mac
    MacBook Pro
    i7 2.9
    8 Gb
    750Gb
    Architectural
    Designer's Discipline Details
    Drafter
    Architectural
    AutoCAD 2013
    Nov 2006
    Portugal
    96
    I think theres no way of doing that.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,582
    Quote Originally Posted by sparklerach View Post
    Hello There,
    Thanks
    Do you use all of them? what i do, is move the PC3 files into a backup folder i've created so they don't show up on the list at all. i don't delete them just in case i might need them down the road. also, go delete any printers you don't use from Windows, but be careful not to delete something you might need, so double check.
    i have basically 3 plotters in my selection, it's great - very clean, none of the "DWF6 ePlot.pc3" or "PublishToWeb PNG.pc3" or any of those on my list.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Full Member
    AutoCAD 2013
    Nov 2006
    Perth, Australia
    89
    Thanks StykFacE,
    I do use alot of them. We print all drawing to dwf. We then print to either the A4 printer or the big plotter for large drawing. We also need to print to pdf, eps, etc foe some drawings. But I will get rid of the rest and see how that goes.
    Thanks Again,
    Rach
  1. When I change the color the dimensions change!
    By Mark Costantino in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2009, 05:55 pm
  2. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
  3. Layer Order.
    By Skeeps in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2006, 03:23 pm
  4. HP plotters, Second Hand UK sellers - where!!
    By QfanatiQ in forum Catch All
    Last Post: 6th Jan 2006, 05:28 pm
