Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    BTStark is running LT.
    Express Tools are not available for LT.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  2. #12
    Forum Newbie
    AutoCAD LT 2008
    Mar 2008
    Cluj-Napoca, Romania
    4
    Default Block counting in LT
    Here is a way I used to count blocks in acad LT
    First you must create a template in a txt file.
    You write the following:
    BL:NAME C008000
    BL:NUMBER N008000
    After that you save the file and go to acad. In the command line you write attext, you choose a file format( cdf for example), you select the objects( you can select the whole drawing), choose the template file and the output file.
    The result will look like this
    'Termosta', 1
    'Termosta', 2
    'Termosta', 3
    'Termosta', 4
    'Termosta', 5
    'Termosta', 6
    You can add some attributes if you want too.
    Hope this is helpfull.
  3. #13
    Forum Newbie
    AutoCAD 2004
    Jul 2008
    7
    Default object count
    if you dont have express or bcount command or eattext command or if your using older versions of autocad , you can also use the erase command and simply window all the objects....it will give you how many objects that have been chosen.
    but dont hit the <return> on the keybored
  4. #14
    Forum Newbie
    AutoCAD LT 2012
    Feb 2012
    1
    Default question
    Quote Originally Posted by dacoba View Post
    BL:NAME C008000
    BL:NUMBER N008000
    'Termosta', 1
    'Termosta', 2
    'Termosta', 3
    'Termosta', 4
    'Termosta', 5
    'Termosta', 6
    Can you please run me through on how to make a txt template file...i tried but I think I did something wrong and I really need to count blocks some other way since I am using the LT version and not able to do BCOUNT
    thank you
  5. #15
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,094
    The method referred to in post #12 requires the user to create an ASCII template file. The procedure for doing this is covered in your AutoCAD Help files under the topic Extract Attribute Block Data (Advanced).
    "Each field in the template file extracts information from the block references in the drawing."
    This procedure requires the block to have at least one attribute associated with it and included in the template file.
    You can find out about another option available to LT users here...http://ltisacad.blogspot.com/2011/05...nting-and.html
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,094
    kdmae3: Did you manage to figure it (template file) out or did you resort to an alternative method?
  7. #17
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Perhaps DATA EXTRACTION might be another way to go? MENU BAR > TOOLS > DATA EXTRACTION.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,094
    Re: Template file. Should you not specify at least one attribute in your template file this is what the outcome will look like.
    Command: ATTEXT
    Select objects: Specify opposite corner: 339 found
    Select objects:
    ** No Attribute fields specified.
  9. #19
    Super Member
    MisterJingles's Computer Details
    Windows 7 Pro SP 1
    Dell Vostro 3750 i7 2.0GHz
    6GB
    Mechanical 2011
    Apr 2009
    South Africa
    511
    When I need to count blocks quickly without needing to do a full Data extraction I use the Select Similar command. Its nifty when you have a large building and for instance the boss needs to know how many single plug sockets and double plug sockets there are.
    The only snag is you need to be careful with your use of layers as ACAD wont see 2 identical plugs as similar if they are on different layers.
    Don't forget your towel!
  10. #20
    AutoCAD 2012
    Nov 2011
    3,134
    The FILTER command also works well, and doesn't worry about layers, unless you instruct it to.
    A really good tool, especially if you save a few filters which you might like to use on subsequent occasions, making it faster still.
  1. Determine Surface areas of 3D solids
    By just4geeks in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jun 2008, 02:15 pm
  2. Blocks for any drawing
    By DODGE in forum AutoCAD Drawing Management & Output
    Last Post: 13th Feb 2007, 10:47 am
  3. Blocks slowing drawing down..!
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2006, 03:42 pm
  4. Calculate quantity of material
    By dabaci in forum AutoCAD General
    Last Post: 8th Aug 2006, 06:52 pm
  5. cost/quantity measuremment
    By oksng in forum AutoCAD Drawing Management & Output
    Last Post: 21st Sep 2004, 04:16 pm
