Results 1 to 2 of 2
    RSS Feed Posting Robot AutoCAD Insider's Avatar
    Sep 2006
    350
    Autodesk RSS Feed Set All Object Properties to BYLAYER in AutoCAD 2008
    Sometimes you’ll run into a drawing where the object properties are set to a specific value, like a certain color or linetype, instead of BYLAYER. When you change the layer’s property, those particular objects don’t change. Sometimes that is what you want, but often it isn’t. Until now you had to manually go through and edit each of the object properties.
    There is a new tool in AutoCAD 2008 that enables you to quickly apply the BYLAYER property to multiple objects, including those within blocks definitions. The new SETBYLAYER command is available on the modify menu. After selecting the objects you want to change, a Settings option enables you to specify which properties you want to be included in the operation. Additional prompts allow you to choose if you want to change object properties that are currently set to BYBLOCK and/or objects within blocks.
    View Animation
    More...
    AutoCAD Insider - Autodesk blog by Heidi Hewett
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Oh, now that IS worth having. OK, I could have written a simple LISP routine to do that but hey...
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
  1. Tables from Object Data in AutoCAD 2008
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 21st Feb 2007, 04:30 pm
  2. Layer Properties in AutoCAD 2008
    Last Post: 14th Feb 2007, 09:36 pm
  3. Object Properties
    By Chris in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Mar 2006, 12:58 am
  4. Hesitation with object properties when object is selected
    By Jaxom in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Jan 2006, 07:56 pm
  5. Object Layer Properties
    By Mike Maddeford in forum AutoCAD Drawing Management & Output
    Last Post: 29th Dec 2005, 05:14 pm
