Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member DODGE's Avatar
    AutoCAD 2012
    Oct 2006
    Melbourne The land of Oz.
    445
    Default Inserting Blocks
    Hi All
    I have been playing around with blocks the last few days
    and have no problem creating and saving them.
    However I always seem to have problems inserting them accurately.
    I have for instance cabinet modules as blocks and I need to insert
    them next to other items, cabinets etc and snap them onto them.
    How do I do this? I can never seem to snap them on accurately.
    I have my block set up with an insertion point etc but I always have this problem and end up just fluffing it in so it looks right.
    Thanks for any help
    Dodge
    Senior Member Starkey's Avatar
    AutoCAD 2007
    Nov 2006
    206.Seattle.WA
    169
    Do you have your Osnap turned on with things like midpoint, endpoint, nearest, etc. checked on? It seems like you have done everything correctly while inserting the block, you just need your Osnap turned on to snap blocks next to other blocks.
    "You have to flatten them first. But then they won't be 3D anymore."
    -Alan Cullen
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    ooooooooo.....DODGE,
    This should be straight forward. Make sure your insertion point is correct. I create 2 blocks normally....one for insertion on the right side of an object, and one for insertion on the left side.
    I you have selected an insertion point that can snap to a specific point on the adjacent object, then it should work.
    Get back to me with some more data......also post one of your blocks up so I can have a bit of a play with it....
    AutoCAD 2012
    Oct 2006
    445
    Thanks Guys
    I think it was me. I had my osnap on but not all the boxes checked, dumb. It seems to be ok now.
    Dodge.
    PS Like da hat Alan looks a bit like John Wayne.
  5. #5
    Map 3D 2009
    Jun 2006
    4,181
    Quote Originally Posted by DODGE View Post
    Old army issue...............makes great fishing clobber..........
  6. #6
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    Thanks Guys
    Dodge.
    ew, yuck, you put them all on? i use an OSNAP setting of 47. that works perfecto.... for me anyways. lol
    you use AutoCAD 2006 full right? well instead of creating two blocks like Alan says (sorry man, no offense here just giving more input, lol) you can use the "Point" Parameter in creating a Dynamic Block, and use the Ctrl key to swap the "insertion points" of the block. makes life MUCH easier....
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  7. #7
    Map 3D 2009
    Jun 2006
    4,181
    I can see I'm going to have to learn up on these dynamic blocks....
  8. #8
    AutoCAD 2007
    Nov 2006
    206.Seattle.WA
    169
    Yes, I forgot about dynamic blocks until today. I was able to use the stretch command for one. They really do come in handy!
    -Alan Cullen
  9. #9
    Map 3D 2009
    Jun 2006
    4,181
    DODGE.....further to what Styk said......read up on assigning your often used osnap modes to your function keys (F2, F3 etc). You'll find it much quicker to invoke a particular osnap mode by simply pressing a function key.
    You set it up through your CUI.
  10. #10
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    Or just right click while holding down your shift key. This will open a pop up menu containing all of your osnaps. Just pick the one you need. I keep Endpt, Midpt and Intersection running all the time. Any others, I just pick from the shift+right click menu.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  1. inserting window/door blocks into 3d model?
    By no fixed abode in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Oct 2006, 03:17 pm
  2. Inserting blocks
    By misha in forum AutoCAD General
    Last Post: 1st Jun 2006, 02:33 am
  3. setting the drawing scale/inserting title blocks
    By kaya in forum AutoCAD General
    Last Post: 17th May 2006, 10:42 pm
  4. Inserting blocks and XREF's on Layer 0
    By Barry Clark in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jul 2005, 03:41 am
  5. Inserting Blocks for my new palette
    By hyposmurf in forum AutoCAD General
    Last Post: 10th Oct 2003, 02:20 pm
