+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Junior Member
    Using
    AutoCAD LT 2006
    Join Date
    Feb 2007
    Posts
    11
    Default Dimensioning In Paper Space At Various Zoom Levels?
    Hi,
    I'm using AutoCad LT 2006, and my question is about adding dimensions in paper space.
    Heres my scenario: I have site layout at 1"=40'. I want to create a new layout with a viewport that zooms in on a small section of the site layout. I want to then lock the paper space viewport view and add dimensions in paper space that have the same appearance as if I had drawn the dimensions in model space. Since the viewport scale is dynamic (I can zoom in or out to any size), how do I adjust my dimension scale to match whichever zoom level I choose?
    I know I can create a dimension layer in model space, but I want to learn how to create the proper dimensions in paper space no matter what the viewport zoom level is.
    Clear as mud?
    Thanks,
    ~bugleboy62
  2. #2
    Super Member
    Using
    Architecture 2010
    Join Date
    Jan 2006
    Location
    canada, eh!
    Posts
    607
    Default
    you will have to create a new dimstyle...open up the dimstyle and select the style that you used in model space...once selected click on the new button and rename the dimstyle and hit the continue button...next go to the fit tab and change the value of use overall scale of: to 1 and exit the dimstyle...then make sure that the dimlfac variable is set to 1...
  3. #3
    Banned Alan Cullen's Avatar
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Cairns, Queensland, Australia
    Posts
    4,181
    Default
    There is also another way to do it.......only have one dimstyle (the one you normally use) and have the text size of that style set to 0. (You can set the required text size when you fire up the text command).
    Then add the following line to the User Defined Command Aliases section of your acad.pgp file......
    DS, *DIMSCALE
    That way whenever you want to add dimensions at a specific scale, just type DS and enter the required scale...and Bob's your uncle.
    So to add text to paper space just type DS and enter 1.
    I find it all much easier and quicker to do this than to be forever changing dimstyles.
  4. #4
    Senior Member
    Using
    Architectural DT 2007
    Join Date
    Aug 2006
    Location
    Midwest
    Posts
    218
    Default
    If you do it hadardman's way, you will need to set up associative dimensioning as well. To do this, type in "options" and then under "user preferences" check the box next to "Make new dimensions associative"
  5. #5
    Forum Deity
    Using
    Civil 3D 2008
    Join Date
    Sep 2006
    Location
    Pittsburgh, PA, USA
    Posts
    3,581
    Default
    Text height of style used in Dimension Style = 0
    Dimassoc = 1
    Dimscale = 0
    Dimension in Paperspace; all text, arrowheads, etc. should plot at the same size regardless of viewport scale.
Similar Threads
  1. LTSCALE - Model Space/Paper Space Differences and problems
    By Fedge in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2011, 02:33 pm
  2. DIMENSIONING DEBATE: MODEL OR PAPER SPACE?!
    By jt6572 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Nov 2008, 05:06 pm
  3. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
  4. shortcut to toggle model space to paper space
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 3rd Feb 2006, 05:58 am
  5. Pasting to Paper space from paper space
    By brast in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jun 2003, 03:58 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
