Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2006
    Mar 2007
    Brazil
    3
    Default plot in multiple pages
    hello, i need to plot a 1:1 draw in A4 paper, but the drawing is going to use more then one sheet. is there any "automatic" way to do that? (autocad automatically "calculate" how many sheet is going to need and plot-it)
    or do i have to manually plot one part at time? (mark on the drawing the size of the paper and then zooming it in the viewport)
    i'm using autocad 2006, and i'm quite noob wen it comes to plot using the viewports. =D
    ps: i'm from Brazil, sorry about any grammatical error.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    are you wanting to plot multiple Files? or multiple Layouts? if you have for instance 10 Layout tabs, just go to File -> Publish to plot them all at once. or, for example, if you have 10 seperate *.DWG files, then type SSM at the command line to bring up the Sheet Set Manager, from there you can bring all the files into here, then set them up to plot all at once. Hope this helps.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Forum Newbie
    AutoCAD 2006
    Mar 2007
    Brazil
    3
    no, it's a single drawing.
    it's like having a baseball-bat drawed, and it has like 1400mm of size. and i need to plot-it in 1:1 scale, so it's going to need to print in 5 sheets of A4, then i'll glue or tape (or something) the sheets together. to use the printed baseball-bat as lead to cut the wood or something.
    do i have to manually plot each part?
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,433
    I think you're going to have to plot each viewport, one at a time using the Window option in your plot dialog. It shouldn't take more than a minute to send all 5 to the printer. Now if you had 50 viewports, that would be a different story.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  5. #5
    Senior Member New2CADmike's Avatar
    AutoCAD 2000
    Jun 2006
    Central California
    198
    Skiter..I think they call it .tileing... I have a program called quickcad (made by autodesk)..no longer though..and if you had a full scale item drawn that was 12 feet long by 4 feet wide,you could print that using letter size paper by taping all the tiles(sheets) together..It even made little tick marks in the corners of the sheets to line up the drawing..It might be 20 sheets by 15 sheets wide but it worked great..I guess that autodesk must think that if you can afford a multi thousand dollar program such as Acad 2007 or simular than you must be able to buy a wide scale printer..Quick cad was a 60 dollar program ..I have Acad 2000 but no decent printer..What I do if I need something large printed is take the file down to fedex-kinkos and with their printers they can do it for you..Mike
    Using ACAD 2000
  6. #6
    Forum Newbie
    AutoCAD 2006
    Mar 2007
    Brazil
    3
    thanks Mike, that's exactly what i need. to bad to know autocad don't have something like this. (tileing)
    i'll try to make a search to see if i can find anything that i can put to use.
    in the mean time i'll try to do-it manually, but i'm getting myself seriously beaten by the printable area. lol
  1. how do I plot 14 pages to a small pdf file size?
    By Extreme Noob in forum AutoCAD General
    Last Post: 31st Jan 2007, 10:58 pm
  2. multiple pages?
    By johnnybond in forum AutoCAD Beginners' Area
    Last Post: 21st Sep 2005, 02:50 pm
  3. Printing multiple pages in AutoCad 2000
    By jerthebear in forum AutoCAD Beginners' Area
    Last Post: 8th Sep 2005, 03:52 pm
  4. Print 1 large page on multiple smaller pages
    By malthazar in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2005, 09:32 pm
  5. Can I have multiple pages in one .dwg file?
    By NewGuy in forum AutoCAD General
    Last Post: 18th Sep 2003, 04:38 am
