Results 1 to 4 of 4
    Junior Member
    AutoCAD 2007
    Mar 2007
    22
    Default sketchup materials
    alright I've been rendering this house I've been designing in sketchup, its very easy to use but i noticed that the materials are very small scale and when i put them on my house they are very small and usually just a blur. can i increase the size of the material? or are there any other things i can do to fix this?
    thanks
    Senior Member architecture68-raff's Avatar
    ADT 2005
    Nov 2006
    Chicago, IL
    159
    You can edit definitions of the materials in the "Material Browser" or the "Material Editor" under the Windows pulldown
    Junior Member
    AutoCAD 2007
    Mar 2007
    22
    sweet thanks
    Forum Newbie
    Architectural DT 2006
    Feb 2008
    4
    Make sure when you import the file the options is set to inches not feet. That is why everything is coming in oversized.
  1. AutoCAD to SketchUp
    By vibi in forum SketchUp
    Last Post: 9th Jul 2011, 01:59 pm
  2. SketchUP 6 is here.
    By f700es in forum SketchUp
    Last Post: 16th Jan 2007, 09:32 am
  3. Autocad2006 to SketchUp
    By Mwason in forum SketchUp
    Last Post: 13th May 2006, 01:08 pm
