Results 1 to 3 of 3
    Full Member
    AutoCAD 2009
    Dec 2006
    28
    Default How do I align text within a block when rotating a block
    This may be hard to explain so bear with me...........
    I have to place windows onto a building floor plan, there are about 3 different styles of windows with around 100 each. Each window need an elevation callout pointing at it. So I make a block out of the window and place an elevation callout within the block, pretty simple but as I rotate around the building the block requires rotation and then the text in the callout is rotated as well.
    I am a stickler on this, no matter which way an elevation callout points, the text must always be vertically aligned. Creating the callout separately from the windows is how I've always done it but I've never had to do it in this repetition.
    I know I could just create 4 separate blocks, NSEW kind of thing but is there an easier way? Just trying to save a few minutes and learn something.
    Thanks,
    troutspinner
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    yes, Dynamic Blocks. type _ai_invokenfw at the command line and follow the few tutorials they have. easy stuff.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    AutoCAD 2009
    Dec 2006
    28
    Aw man, now I feel like an idiot! Thanks though! Pretty simple.
    troutspinner
  1. Convert text to a block
    By ORgrown in forum AutoCAD General
    Last Post: 22nd Jul 2013, 09:29 pm
  2. Select Cad Block on WEB identifying Spec of Block
    By Sondrus in forum Web Design
    Last Post: 12th Mar 2007, 03:49 pm
  3. Getting Attributes for one block reference w/many block inserts?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Oct 2006, 03:38 am
  4. automated block text?
    By nscherneck in forum AutoCAD Beginners' Area
    Last Post: 8th Mar 2006, 03:25 am
  5. Editing Text in a block
    By cadaholic in forum AutoCAD Beginners' Area
    Last Post: 10th Aug 2005, 03:31 pm
