Results 1 to 5 of 5
    Full Member
    AutoCAD 2007
    Feb 2007
    26
    Default Light Glyphs in Autocad 2007
    I can't find the light glyphs. I know the lights are there because they work! But to move them I must see them... I tried LIGHTGLYPHDISPLAY but it won't make the glyphs visible. Camera glyphs work fine. Anyone else have this problem?
    Senior Member CromCruithne's Avatar
    AutoCAD 2007
    Jan 2007
    Miserable Mississippi
    280
    LIGHTGLYPHDISPLAY works for me, but you can also use the Lighting control panel in the Dashboard to control this.
    -Crom
    Full Member
    AutoCAD 2007
    Feb 2007
    26
    Light glyphs work fine for some lights, but not distant lights. And then, there's the problem of removing something you can't see!
    Full Member
    AutoCAD 2007
    Feb 2007
    26
    Got it. Quote from the Help section "There is no light glyph to represent a distant light in your drawing."
    When all else fails - read the instructions?
  5. #5
    AutoCAD 2007
    Jan 2007
    280
    Usually a good bet.
    ACAD actually has a decent help file, so it's worth using every now and then.
    -Crom
  1. AutoCAD 2007 & AutoCAD LT 2007 Essentials Training
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 13th Jan 2007, 12:00 am
  2. activating sketch command in autocad light 2000
    By markcad45 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2006, 06:08 pm
  3. activating sketch command in autocad light 2000
    By markcad45 in forum AutoCAD Drawing Management & Output
    Last Post: 19th May 2006, 02:20 am
  4. light going through surface
    By dsdsdsdsd in forum AutoCAD Drawing Management & Output
    Last Post: 14th Dec 2005, 06:59 pm
  5. From AutoCAD to Light Wright 3
    By midasxl in forum AutoCAD Drawing Management & Output
    Last Post: 29th Oct 2004, 02:44 pm
