johnengineer Posted March 16, 2007 Share Posted March 16, 2007 How do I change the base point of a block? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 16, 2007 Share Posted March 16, 2007 Is it a plain-o-vanilla block or a dynamic block? Quote Link to comment Share on other sites More sharing options...
johnengineer Posted March 16, 2007 Author Share Posted March 16, 2007 Plain block. Quote Link to comment Share on other sites More sharing options...
dbroada Posted March 16, 2007 Share Posted March 16, 2007 There are a number of ways. If the block is defined external to your drawing you can open that drawing. Now either select all the objects and move them using a suitable reference point to 0,0,0. Just to be certain set BASE to 0,0. This is the method I prefer. Alternatively just set BASE to your reference point. Now you have to redefine the block within the drawing. To do this INSERT the block again but make sure you navigate to the file rather than accept the current definition. Accept the "redefine" option. Note that all instances of that block already in your drawing will move by the amount you have moved its base. If the block is only defined within the drawing you should open the block with either the REFEDIT or BEDIT interface and basically repeat the above. Quote Link to comment Share on other sites More sharing options...
DennisVercauteren Posted October 5, 2010 Share Posted October 5, 2010 Thanks a lot, I helped me very much Quote Link to comment Share on other sites More sharing options...
