Text to Mtext and back
muck
Subject: Text to Mtext and back.
Is there any good program or way to change text to mtext?
I think you can explode mtext to make it text but what about making
text into Mtext? Also would be interested in programs that match text
style and properties of Mtext to Text.
thank you,
There is an Express tool called TXT2MTXT.
Use the MATCHPROP command to match the properties. For changing the stile -use the properties window or the text stile control drop-down
There is a tool in the express menu. It is called TXT2MTXT
You can use the MATCHPROP command to copy the text style of the mtext object to the text object.
  • 2 years later...
Is it normal that i can't explode MTEXT to TEXT anymore with r2010 (Which i hate more and more every day) ?
(oops... i must be at the wrong place at the very wrong moment!)
