Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2007
    Mar 2007
    6
    Default Leader - Mtext issues
    At one time in my life I was a happy camper. I was able to just fly through AutoCAD without too many speed bumps. But as is life, I became too familiar with my way of working. Now something horrible has happened and I feel as useless as a cat driving an 10 wheeler. When I use qleader or "le" as I like to type it in 2007, the Mtext edit box does not come up anymore. I went into Leader Settings and set the "Second Segment Angle Constraint" to horizontal on the "Leader Line & Arrow" tab. That is all I have touched, and cannot find anywhere to get my text box back. on the Annotation tab Mtext is chosen as Annotation Type. I am at a loss here, any help would be greatly appreciated.
    Super Member yedan's Avatar
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    have you by any chance got a reuse option ticked in your annotation tab under reuse annotations?
    Forum Newbie
    AutoCAD 2007
    Mar 2007
    6
    I have tried those options, it just copies the last used annotation. Which it is better than me just right clicking out of the command like I usually do
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    hmmm dont know what to say then for me i select leader, click start point, click next point, hit right click three times and bang there is my mtext editor box and im ready to type,
  5. #5
    Forum Newbie
    AutoCAD 2007
    Mar 2007
    6
    Thats what I used to do too. Now when I do that, I click right out of the command. I need to figure this out.
  6. #6
    Forum Newbie
    AutoCAD 2007
    Mar 2007
    6
    Bump before i pull whats left of my hair out
  7. #7
    Forum Newbie
    AutoCAD 2007
    Mar 2007
    6
    Still not working, any ideas???
  8. #8
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,433
    Here's the procedure:
    QLEADER
    Specify first leader point, or [Settings] <Settings>: Place 1st point
    Specify next point: Place 2nd point
    Specify next point: Place 3rd point
    Specify text width <0">: Hit Enter
    Enter first line of annotation text <Mtext>: Hit Enter
    You should now have your Mtext Editor
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  9. #9
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    there's a SETVAR command for leaders - which determines whether they have tails etc
    sorry I can't remember what it's called, and can't look on this machine - but somebody else may be able to help out if I've jogged any memories
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  10. #10
    Senior Member brassworks's Avatar
    AutoCAD 2008
    Sep 2006
    Woburn, Massachusetts, USA
    127
    Check out your AutoCAD Preferences/Options dialogue box. Type "PR" or "OP". Under the "User Preferences" tab, look at the Shortcut menus options. Maybe your machine has defaulted to the right-click/repeat command option. I don't know if this will help, but it might be the option that is creating the problem. These things can be just plain confounded!
    Did you hear about the drafter who died? He couldn't draw his breath.
  1. Can Lisp use mtext to make multi string mtext editor?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2006, 03:22 am
  2. Arc-ed Leader
    By J-LYLE in forum AutoCAD Drawing Management & Output
    Last Post: 3rd May 2006, 08:32 pm
  3. Mtext issues & new Assoc codes
    By Rbtdanforth in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Mar 2006, 04:57 pm
  4. Mtext attached to leader
    By stortiw in forum AutoCAD Drawing Management & Output
    Last Post: 17th Feb 2006, 05:36 am
  5. MTEXT created in same MTEXT editor on different layers?
    By hyposmurf in forum AutoCAD General
    Last Post: 5th Sep 2003, 12:54 pm
