Closed Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Beginner FAQ
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,641
    Default Beginner FAQ
    Before Posting
    Browse the help file, hit F1 while in Autocad.
    Run through the 'Learning Assistance' CD tutorials.
    1) I can't draw accurately ?
    Use OSNAPS, found in the TOOLS>Drafting Settings menu
    or 'type and shoot', click somewhere then using ORTHO
    type in a size.
    2) Why do I only have a few linetypes available ?
    You need to load more linetypes using the LAYER manager.
    3) I can't plot to the right scale ?
    You need to setup a LAYOUT with the correct scaled viewport
    and plot settings
    4) I see all my linetypes as continous on screen. whats wrong?
    Adjust linetypescale (default value is 1.000). By hitting Ctrl+1
    and seeing the properties docker popping up.
    5) I have assigned colour to newly created layer. but all
    objects made in that layer show different colur?
    check..if the current colour is not "bylayer", your object will not
    have same colour as you assigned to its layer. select "bylayer"
    option from colour manager box from properties toolbar.
    6) I can't get the right scale in Paperspace.
    Instead of using zoom 1/(whatever) try using 1/(whatever)XP, it scales in paperspace.
    Please post up any other items to add.
    Draft 10/03/05
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
    Senior Member
    not applicable
    Jan 2005
    INDIA
    107
    i see all my linetypes as continuos on screen. whats wrong?
    adjust linetypescale (default value is 1.000).
    i have assigned colout to newly created layer. but all objects made in that layer show different colur
    check..if the current colour is not "bylayer", your object will not have same colour as you assigned to its layer. select "bylayer" option from colour manager box from properties toolbar.
    LESS IS MORE!! More is "NO MORE".
    [][] LESS IS MORE. MORE IS NO MORE [][]
    Rajesh Advani
    Senior Member Jamalama's Avatar
    Civil 3D 2010
    Mar 2005
    Colorado, USA
    157
    Life comes down to 4 letters...PRFF
    Pride Respect Friends Future
    The Rest is Just Filler
    Full Member
    not specified
    Oct 2005
    52
    Default Re: Beginner FAQ
    Quote Originally Posted by Mr T
    You could also load linetypes w/ LINETYPE command.
  5. #5
    Forum Newbie
    not specified
    Dec 2005
    BAHRAIN
    3
    Quote Originally Posted by Jamalama
    also, open the "viewports" menu tab(right click on any icon and select viewports) then at the menu tab just type in ur desire desired scale and presto..... but u have to be in model space before typing ur scale....
  6. #6
    Full Member
    AutoCAD 2009
    Mar 2005
    46
    Quote Originally Posted by CADdilacad
    If you highlight the viewport you can change the scale in paperspace.
    I do it all day everyday.
  7. #7
    Junior Member
    not specified
    Jul 2006
    Tacoma, Washington
    23
    thanks Mr T for the good idea. helps newbies like moi
  8. #8
    AutoCAD 2007
    Nov 2002
    1,641
    This FAQ would be good as a wiki type thread ?????
    Nick
  9. #9
    AutoCAD 2007
    Nov 2002
    1,641
    Smile
    Wow 10,000 views.
    Nick
  10. #10
    Full Member
    Inventor 2015
    Jun 2008
    Detroit, MI.
    58
    Quote Originally Posted by Jamalama View Post
    Quote Originally Posted by CADdilacad View Post
    Quote Originally Posted by pmcwilliams View Post
    Select the view port in paperspace and in properties change the "custom scale" to whatever you want it to be.
