Results 1 to 6 of 6
Thread: Origin Point
    Full Member
    AutoCAD 2008
    Aug 2006
    ellesmere port, england
    96
    Default Origin Point
    I Am Just Starting To Learn Inventor Am A Solidworks User Trying To Transform. Can Someone Tell Me How I Can Lock Line, Drg Etc
    On To The Origin Point So My Drg Is Locked To Centre Of Screen
    My Drg Moves When Dimensions Are Added I Want To Keep Drg In Position I Am Using Version 10 Have A Book Inventor 11 This Has Asetting In Options "autoproject Origin Create Point" Where Is The Setting On 10
    Regards
    Fifth Texas
    into any cad design
    love using 3D
    love using solidworks
    learning inventor
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,641
    Dimension the postion rather than the line. Run thru the 'Sketching' section of the help file and mainly look at the 'constraints' section.
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
    Senior Member
    Inventor 2008
    Sep 2006
    Auburn, WA
    192
    I believe that is new for inventor 11. What you can and should do is, expand the origin folder at the top of your model tree, select the "project geometry" tool, select "center point from your origin folder. This will give you a grounded origin point to attach to. You will need to do this for every sketch you start. It sucks but it is what you have to work with. Like I said, this is fixed in IV11.
    You are on the right track though. Always fully constrain your sketches. Never use the "fix" constraint under any circumstances. Always constrain to your origin, this will help you later on when you need to create work planes and when constraining in assemblies.
    David
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    1TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    Quote Originally Posted by Aardvark View Post
    There is an easy way and will stop you from having to do this process of expanding the origin folder and projecting geometry etc every time, and that by setting up a default folder with projected origin inplace this can be done with any version of Inventor
    1. Follow Aardvark's process above
    2. Save as, then goto program files/IV10/Templates/ and save in there as (you name or what ever you like).ipt
    Then when you go FILE>NEW your temple is there, select it and the projected origin is in place for you.
    always start your sketch from the origin.
    You can also set all the settings for your liking before you save your own template.
  5. #5
    Senior Member
    Inventor 2008
    Sep 2006
    Auburn, WA
    192
    Deelay,
    The only reason I didn't include that bit ( and I almost did), is that this projects the origin point into the first sketch of every new part (sounds ok so far right?) but this happens when you open derived parts, iPARTS or SAT, STEP, IGES, etc as well. Not horrible, but it can get annoying to have this sketch with a dot in it that you can't remove.
    That being said, I agree it works very well and you don't have to repeat all of those steps every time you start a new file. You will still need to do this for every subsequent sketch in that part.
    David
  6. #6
    Windows 7
    8GB
    1TB
    Portable TB drive
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    I had an Idea you knew how to to it as by reading your posts I can tell your well clued up with Inventor
  1. how to move origin point ?
    By airs in forum AutoCAD Beginners' Area
    Last Post: 20th Nov 2006, 12:52 am
  2. Hatch Origin
    By gortex in forum AutoCAD Drawing Management & Output
    Last Post: 5th May 2006, 04:47 am
  3. Origin of drawing
    By engineer1 in forum AutoCAD Beginners' Area
    Last Post: 2nd May 2006, 03:36 pm
  4. paperspace origin ?
    By bc in forum AutoCAD Beginners' Area
    Last Post: 7th Oct 2005, 08:53 pm
  5. changing Origin USC
    By wado66 in forum AutoCAD General
    Last Post: 25th Jun 2005, 07:17 pm
