Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2000i
    Apr 2007
    5
    Default No function definition:VLAX-PRODUCT-KEY
    I'm using AutoCAD2000i and Express Tools
    These Express Tools commands all gave the error "No function definition:
    VLAX-PRODUCT-KEY":
    layfrz
    layoff
    how do I fix this problem?
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    Type (vl-load-com) in command line and try one more time. If it work write this expression to acaddoc.lsp file (in 2000i it seems into ...AutoCAD 2000i/Support folder).
    Forum Newbie
    AutoCAD 2000i
    Apr 2007
    5
    (vl-load-com) doesn't work and i can't find the acaddoc.lsp file
    AutoCAD 2008
    Nov 2005
    1,427
    Type in command line:
    Code:
    Command: (vl-load-com)
    Command: (vlax-product-key)
    "Software\\Autodesk\\AutoCAD\\R17.0\\ACAD-5004:409"
    If (vlax-product-key) returns your product Registry Key your Express Tools functions should work. If after (vl-load-com) function (vlax-product-key) again returns "No function definition: VLAX-PRODUCT-KEY" you have problem with VisualLISP extention loadind.
    Use Windows Search... If you can't find acaddoc.lsp anyway, open Notepad, write line (vl-load-com) and save it in Support folder as acaddoc.lsp.
  5. #5
    Forum Newbie
    AutoCAD 2000i
    Apr 2007
    5
    thank you but it still doesn't work, any other ideas?
  6. #6
    Full Member
    AutoCAD 2007
    Mar 2007
    27
    Not sure about this, but try typing EXPRESSMENU in the command line.
  7. #7
    Forum Newbie
    AutoCAD 2000i
    Apr 2007
    5
    EXPRESSMENU rebuild the express tool menu but doesn't fix the problem :-(
  8. #8
    Forum Newbie
    AutoCAD 2000i
    Apr 2007
    5
    reply to my own post:
    apparently, the only solution is to re-install autocad and express tool, see below:
    Re: Express tools failure
    Here is a document from our solution database. This sounds like a registry
    problem.
    Solution ID: TS75657
    Title: "ERROR: NO FUNCTION DEFINITION: VLAX-PRODUCT-KEY" ATTEMPTING TO USE CERTAIN EXPRESS TOOLS
    Products: AUTOCAD 2002; AUTOCAD 2000I
    Problem Description: Attempting to executing certain Express Tool commands the following error is displayed at the command line and the
    command fails to run:
    "Error: No Function Definition: VLAX-PRODUCT-KEY"
    Problem Resolution: To resolve this error, apply the latest Service Pack for your product version, or reinstall both the product and the Express Tools.
    For more information about reinstalling your product, see related documents.
    Jeff Hanson
    Autodesk Product Support
    Building Solutions Division
  9. #9
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by burt View Post
    ...and i can't find the acaddoc.lsp file
    As a side note, "acaddoc.lsp" is a user created/maintained file. If you don't have one, it's only because you have not created one. No harm.
  1. Attribute Definition Question
    By ztaylor10 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jun 2007, 12:26 pm
  2. help product by an autodesk educational product
    By music in forum AutoCAD Drawing Management & Output
    Last Post: 26th Sep 2006, 03:33 pm
  3. vlax-get obj coordinates
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2006, 01:57 pm
  4. abut vlax-curve in lisp
    Last Post: 15th Jul 2006, 08:17 am
  5. Attribute Definition
    By Jamalama in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 11:19 pm
