No, not without an add-on like LDD or Civil 3D, or a custom Lisp or VBA routine.
Is there any way to go round an autocad site plan using the ID command and have the coordinates registered automatically to a table in Autocad 2004
PM me your email address.....I'll send you a lisp routine that will do what you're after.
Try this routine.
Code:(defun c:ptt(/ curPt txtObj vlaTxt) (vl-load-com) (setq curPt T) (while curPt (if (and (setq curPt (getpoint "\nPick point > ")) (setq txtObj (nentsel "\nSelect Text, MText or Attribute > ")) ); end and (progn (if (member (vla-get-ObjectName (setq vlaTxt(vlax-ename->vla-object(car txtObj)))) '("AcDbText" "AcDbMText" "AcDbAttribute")) (progn (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-TextString (list vlaTxt (strcat(rtos(car curPt)) ","(rtos(cadr curPt)))))) (princ "\nText on locked layer! ") ); end if ); end progn (princ "\nIt isn't Text, MText or Attribute! ") ); end if ); end progn ); end if ); end while (princ) ); end of c:ptt
what command for this
Looks like PTT.
Code:defun c:ptt
