+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Senior Member nscherneck's Avatar
    Computer Details
    nscherneck's Computer Details
    Operating System:
    Windows Vista 32b
    Using
    AutoCAD 2009
    Join Date
    Mar 2006
    Location
    Costa Mesa, CA
    Posts
    135
    Default Can i display the name of my VPORTS?
    Is it possible to have the name of the VPORT displayed in the VPORT itself?...(i.e. TOP, FRONT, SW ISOMETRIC, etc.)
    This would help me remember how im viewing my object. Thx.
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,090
    Default
    While you can have a Named Viewport I don't believe you can actually display a name in the viewport itself automatically. If you had spent any time "on the board" you would know that the standard convention in orthographic projection is TOP, FRONT, SIDE (usually the right) and ISO (southeast). If you always adhere to that system then there would be no reason to actually name the views.
    If you do something different, like have an ISO viewed from the northwest, then perhaps you should just place some text inside the viewport as a reminder. The text could be placed on the Defpoints layer or another layer that isn't plotted.
  3. #3
    Full Member Gar's Avatar
    Using
    AutoCAD 2007
    Join Date
    May 2006
    Location
    Stokesdale, NC
    Posts
    71
    Default
    At my old job we used to commonly title or tag viewports with their elevation... ie: Plan view, front, side, etc... we just put a line of text on top of the viewport in paperspace...
    ...the above was my two cents...
    If you think you can do a thing or think you can't do a thing, you're right.
    Henry Ford
    ...and "can't" is a bad four letter word.
  4. #4
    Senior Member RFRUSSO's Avatar
    Using
    Architectural DT 2006
    Join Date
    Mar 2007
    Location
    Dark side of the Moon
    Posts
    285
    Default
    You can display the name of a viewport. Here are the steps to do so:
    1. insert Mtext.
    2. before typing any thing, right click in the mtext box and select "insert field"
    3. Change the field category to object
    4. in the object type column, use the selection button. That window will go away and you can then click on the viewport that you wish to display the name of.
    5. when the field window pops back up you will see some properties listed. Select "object name" and then OK.
    You will now have your viewport name displayed.
Similar Threads
  1. So What's the deal with PS Vports?
    By maize31 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2006, 04:41 pm
  2. Box pre-display gone
    By jason3515 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jun 2006, 05:31 pm
  3. ID display
    By daiharv in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd May 2006, 05:11 pm
  4. display order help
    By kaya in forum AutoCAD General
    Last Post: 2nd May 2006, 09:42 pm
  5. Scaling Vports in Metric and Plotting
    By boognish in forum AutoCAD General
    Last Post: 17th Nov 2005, 08:50 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
