Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
  1. #11
    Junior Member
    AutoCAD LT 2005
    Apr 2013
    10
    I just joined today so I'm hesitant to start a new topic, hopefully my question will fit in here. Is there a setting which will make nodes show up when I print my drawing?
  2. #12
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by Imamess View Post
    Welcome. They should print unless they are on a no-plot layer. Maybe describe the problem in more detail.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  3. #13
    Junior Member
    AutoCAD LT 2005
    Apr 2013
    10
    Quote Originally Posted by rkent View Post
    Maybe I used the wrong term, is 'handles' what I mean? I would like to know where on the drawing the little blue squares are.
  4. #14
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    If you mean grips, then no, there is no way to plot those.
  5. #15
    Junior Member
    AutoCAD LT 2005
    Apr 2013
    10
    Thanks for your reply, got it, I guess I will just stick to what I've been doing which is placing a quarter inch x or cross on top of each one.
    Thanks for the welcome I look forward to being here.
  6. #16
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    And how are you placing this "quater inch x" at each "each one"? You can do this with ddptype and point.
  7. #17
    Junior Member
    AutoCAD LT 2005
    Apr 2013
    10
    Quote Originally Posted by JD Mather View Post
    I'll try. Several commands have been mentioned here that sound interesting.
    I only resorted to this method recently and have only done it for one sheet of drawings, In think I used the copy tool and with snap turned on it snapped to most of the grips, but for the midpoint of arcs I first had to somehow place the end of a line on those grips which I can only do with the grid turned off. I am mostly self-taught and therefore sometimes have the oddest way of doing things.
  8. #18
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    I am curious as to what you were doing this for? Maybe there is a much simpler method we could clue you into.
  9. #19
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    .... which I can only do with the grid turned off.....
    I turned off the grid in my second CAD class back in '87 of the last century. Ignored any book suggestions that I count dots.
    Offset trim/extend otracking osnaps I find much faster.
    You might attach a dwg file here for some pointers on alternative techniques.
    I am mostly self-taught, or rather, taught by following suggestions by the user community.
  10. #20
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    You are much more patient than I am. It sounds more like a book to throw away.
    I'm also very curious how this is being done without using an osnap. It sounds like a simple matter of just needing to turn on the midpoint osnap, or using the override. In any case, this would be a good place to start with getting some really good help from some really helpful people. It could well make your job a whole lot easier.
  1. UCS Icon Appearance
    By O Snap! in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2017, 03:37 pm
  2. how do I add nodes to a polyline?
    By Anna_here in forum AutoCAD General
    Last Post: 30th Oct 2008, 02:17 am
  3. how do i create mode blue nodes?
    By alessandro754 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Nov 2006, 04:30 pm
  4. spline Problem (nodes)
    By Mr. Sandman in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jun 2005, 05:56 pm
  5. Grips and Nodes
    By DJM001 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jan 2005, 01:18 am
