Results 1 to 8 of 8
    Forum Newbie
    Land Desktop 2004
    Apr 2007
    4
    Default Need label contour...
    hmmm... i hope somebody can help me... how to label contour for polyline with Z value...
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,185
    Try this lisp routine....
    Code:
    ;; CONT_TXT.LSP   v1.0 MAY 1997             PLACE CONTOUR VALUE TEXT ON CONTOURS
    ;; DESCRIPTION:  Routine to place contour value text on contours.
    ;;               Routine works by getting the "ID" of a user selected point along
    ;;               a contour.  The "z" value of this point is then extracted and
    ;;               converted to a text string which is placed on the contour such
    ;;               that the midpoint of the text is the selected point.
    ;;               Text orientation is from a second user supplied point.
    ;;               The routine is set to snap to "nearest".
    ;;               The Main Menu allows for selection of Existing surface contours,
    ;;               Finished surface contours, or exit from the routine.
    ;; SETTINGS:     1.  Contours must hold the "z" value of their elevation.
    ;;               2.  "Units" setting must be 0 degrees to north, with angles
    ;;                   measured clockwise.
    ;;               3.  Previous drawing enviroment variables for "Colour", "Layer",
    ;;                   and "Snap mode" will be restored on exiting the routine.
    ;;               4.  Routine will exit with the text style set to "I" iso3098b.
    ;;               5.  Existing contour text is placed on a layer "conts ns", with
    ;;                   vertical text colour 1 (red) and size 1.8mm.
    ;;               6.  Finished contour text is placed on a layer "conts fs", with
    ;;                   sloping text colour 1 (red) and size 1.8mm.
    ;;               7.  The routine uses the dimensioning variable "Dimscale" to
    ;;                   adjust the text size to suit the intended drawing scale,
    ;;                   i.e.    dwg scale 1:1000   dimscale  1    text size  1.8
    ;;                                     1:500              0.5             0.9
    ;;                                     1:1500             1.5             2.7
    ;; START COMMAND:    CT
    ;; WRITTEN BY:       Alan Cullen - Cairns       May 1997
    ;;;;;;;;;;;;;;;;;;;;;;;;;;;; ERROR HANDLER ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    (defun newerr (/ s)
     (if ocol (setvar "cecolor" ocol))
     (if olay (setvar "clayer" olay))
     (if ocmd (setvar "cmdecho" ocmd))
     (if olderr (setq *error* olderr))
     (if osnp (setvar "osmode" osnp))
     (setvar "textstyle" olstyle)
    ;; (command "style" "I" "ISO3098B" 0 1 0 "N" "N" "N")
     (if (/= s "Function cancelled")
      (if (= s "quit / exit abort")
       (princ (strcat "\nError: " s))
      (princ "\n ERROR....CONSOLE BREAK....PREVIOUS DRAWING STATUS RESTORED          ")
    ;; (setq ocmd nil olderr nil check nil secnam nil fil nil secure nil code nil
    ;;     olay nil ocol nil osnp nil pt1 nil rl nil ang nil lay nil opt nil opt1 nil ts nil)
     (print)
    ;;;;;;;;;;;;;;;;;;;;;;;;; PLACE TEXT ;;;;;;;;;;;;;;;;;;;;;;;;;;;
    (defun place_txt ()
     (setq pt1 T)
     (while pt1
      (setq pt1 (getpoint "\n Pick mid point for text (snap set to nea).....<exit> : "))
      (if pt1
        (setq rl (rtos (caddr pt1) 2 dec))  ;set number of decimal points - last figure in line.
        (setq ang nil)
        (setq ang (getangle pt1 "\n           Pick text orientation point (snap set to nea).....<exit> "))
        (if (not ang)
          (setq pt1 nil)
          (setq ang (- (* 2 pi) ang))
          (setq ang (/ (* ang 180.0) pi))
          (command "text" "J" "M" pt1 ts ang rl)
    ; (setq pt1 nil rl nil ang nil)
    ;;;;;;;;;;;;;;;;;;;;;;;;; MAIN PROGRAM ;;;;;;;;;;;;;;;;;;;;;;;;;;
    (defun c:ct ()
     (setq ocmd (getvar "CMDECHO"))
     (setvar "CMDECHO" 0)                       ;;No commands echoed to screen
     (setq olderr *error* *error* newerr)       ;;Set new error handler
     (setq ocol (getvar "cecolor"))
     (setvar "cecolor" "1")
     (setq olay (getvar "clayer"))
     (setq olstyle (getvar "textstyle"))
     (setq osnp (getvar "osmode"))
     (setvar "osmode" 512)
     (setq ts (getvar "dimscale"))
     (setq ts (* ts 1.8))
     (setq opt T)
     (while opt
      (prompt "\n PLACE CONTOUR TEXT ON CONTOURS - MAIN MENU - May 1997 - Alan CULLEN")
      (print)
      (initget "Existing Finished Intdets Crap eXit")
      (setq opt1 (getkword "\n Select...........Existing / Finished / Intdets / Crap / eXit   (E/F/I/C/X) : "))
      (if opt1
       (cond
        ((= opt1 "Existing")
         (princ "\n EXISTING Surface Contours..............")
         (setq dec (getint "\n Enter number of decimal places... "))
         (print)
         (setq lay "ex conts")      ;set layer name for exist contour text.
         (if (= (tblsearch "layer" lay) nil)
          (command "LAYER" "make" lay "")
          (setvar "CLAYER" lay)
         (if (= (tblsearch "style" "I" ) nil) (command "STYLE" "I"  "iso3098b" 0 1 0  "n" "n" "n"))
         (setvar "textstyle" "I")
         (place_txt)
    ;;     (setvar "textstyle" olstyle)
    ;;     (setvar "CLAYER" olay)
    ;;     (setq olay nil)
        ((= opt1 "Finished")
         (princ "\n FINISHED Surface Contours..............")
         (print)
         (setq lay "D CONTS FS")   ;set layer name for finished contour text.
    ;;     (setq lay "conts crap")
         (if (= (tblsearch "style" "IS") nil) (command "STYLE" "IS" "iso3098b" 0 1 20 "n" "n" "n"))
         (setvar "textstyle" "IS")
         (place_txt)
    ;;     (setq olay nil)
        ((= opt1 "Intdets")
         (princ "\n Intersection Detail Contours..............")
         (print)
         (setq lay "D CONTS INTDETS")   ;set layer name for Intersection Detail contour text.
         (place_txt)
    ;;     (setq olay nil)
        ((= opt1 "Crap")
         (princ "\n Crap Contours..............")
         (print)
         (setq lay "crap")   ;set layer name for Intersection Detail contour text.
         (place_txt)
    ;;     (setq olay nil)
        ((= opt1 "eXit")
         (setq opt nil opt1 nil)
    ;       olay nil ocol nil osnp nil lay nil opt nil opt1 nil ts nil)
     (print)
     (princ "\n Routine exited normally by USER")
     (print)
    Forum Newbie
    Land Desktop 2004
    Apr 2007
    4
    hmm... thank a lot... but im still with my problem with my lisp... cant solve
    the this code...
    (defun c:cpe (/ p val scl)
    (command "wipeout" "f" "off")
    (setq scl (getvar "dimscale"))
    (setq om (getvar "osmode"))
    (setq p (getpoint "\nselect point on contour line: "))
    (setq val (rtos (nth 2 p) 2 0))
    (command "insert" "el_tag" p scl scl pause val)
    (setvar "osmode" om)
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,061
    What problem are you having when you run the routine? Error message?
  5. #5
    Forum Newbie
    Land Desktop 2004
    Apr 2007
    4
    The value of label contour not coming out automaticly. So i must key-in the value directly. But the polyline have the Z value.
  6. #6
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,429
    It may not work by two reasons: Variable ATTREQ = 0 and block 'el_tag' not found in drawing database. I made some alterations to control this things, add loop for multiple labling and error catching function to correct variables restore.
    Code:
    (defun c:cpe (/ *error* scl om atq p val)
      (defun *error*(msg)
        (setvar "OSMODE" om)
        (setvar "ATTREQ" atq)
        (setvar "CMDECHO" 1)
        ); end of *error*
      (command "_.wipeout" "_f" "off")
      (setq scl(getvar "DIMSCALE")
    	om(getvar "OSMODE")
    	atq(getvar "ATTREQ")); end setq
      (setvar "OSMODE" 512)
      (setvar "ATTREQ" 1)
      (if
        (tblsearch "BLOCK" "el_tag")
    	  (while
    	    (setq p(getpoint "\nSelect point on contour line or Esc to quit > "))
    	      (setq val(rtos(last p)2 0))
    	      (command "-insert" "el_tag" p scl scl pause val)
    	    ); end while
        (princ "\n>>> Block 'el_tag' not found! <<< ")
        ); end if
      ); end of c:cpe
  7. #7
    Forum Newbie
    Land Desktop 2004
    Apr 2007
    4
    This my file...
  8. #8
    AutoCAD 2008
    Nov 2005
    1,429
    All work correctly with your file. Does my variant of c:cpe works? I thing reason in ATTREQ value.
  1. Contour Textures for Terrains
    By fahim108 in forum Tutorials & Tips'n'Tricks
    Last Post: 22nd Jul 2010, 10:12 am
  2. upside down contour labels
    By surveyor in forum AutoCAD Drawing Management & Output
    Last Post: 24th Sep 2008, 04:04 pm
  3. automatic contour label?
    By brassworks in forum AutoCAD Drawing Management & Output
    Last Post: 28th Mar 2007, 11:05 pm
  4. label multiple contour elevations
    By rwstephens in forum AutoCAD General
    Last Post: 18th Nov 2005, 07:26 pm
  5. Contour curves to DWG mesh.
    By jmansa in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Sep 2005, 08:54 am
