+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
Thread: Problems
  1. #1
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Sep 2005
    Location
    USA Las Vegas Nevada
    Posts
    33
    Default Problems
    OK yesterday I had to open a drawing that was metric and I posted a thread asking how to change that from metric to inches and I followed as instrructed and it didnt work so I ended up telling my client to change it and it will be sent back to me today. However my problem is not that I go on AutoCad today and do some drawings and I knew something was wrong because when I would try to type a length in in feet it wouldnt do it it would only do it in inches. Then I go to plot my drawings and everything is in metric. I dont know what I did yesterday by changing the drawing but it changed my whole setup and I cant print to a inch/feet scale it is in metric. Also it measures in metric and I dont know what to do to change it back I tried almost everything I could think of like changing the units, etc.
  2. #2
    Banned Alan Cullen's Avatar
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Cairns, Queensland, Australia
    Posts
    4,181
    Default
    In model space you draw in drawing units (not inch, feet, metres, miles). You just assume that 1 drawing unit = 1 inch (your preference for drawing units).
    Now if someone else has drawn the drawing on the basis of 1 drawing unit = 1 foot, then you will have to rescale the whole drawing so that 1 drawing unit = 1 inch. In this case the scale factor will be 12.
    If the drawing was metric, then the scale factor will be different.....
    from mm to inch...scale factor is 0.0394
    from m to inch...scale factor is 39.372
    You can't change your drawing units from inches to feet......it's either one or the other. If you started out using inches....then you must continue to use inches.
  3. #3
    Senior Member Bespoke's Avatar
    Using
    AutoCAD 2008
    Join Date
    Apr 2007
    Location
    West Midlands United Kingdom
    Posts
    214
    Default
    Hi Girls and Boys
    This may seem a daft question but in the land of AutoCAD I assume more country’s use metric than the old pound shilling and pence “feet and inches” so would it not be better to take the big step forward and all go metric? Please don’t shout at me it’s just a thought.
    Regards Alan
    It is said that you never to old to learn, but for someone like me who is as old as a young conker tree it takes a lot longer.
  4. #4
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Posts
    4,181
    Default
    Alan.....that's one of those things that have to be legislated.
    Most European countries are now metric (along with probably most of the planet). However there are still a lot of countries (e.g. USA) that are still imperial. So they have no choice....they HAVE to draw, drink and talk imperial.
  5. #5
    Super Member
    Using
    Architecture 2010
    Join Date
    Jan 2006
    Location
    canada, eh!
    Posts
    607
    Default
    if you're up in canada it's even worse--we use both...for some reason small residential projects are imperial and the rest, commercial, institutional etc., is done in metric!..so i know the conversion scale well...lol...
  6. #6
    Using
    AutoCAD 2008
    Join Date
    Apr 2007
    Location
    Posts
    214
    Default
    Hi One and all
    Just returned from Sleep City in the land of nod so not to with it at the moment.
    It seems the world is a bit backwards when it comes to going forward, all I can say “it’s **** poticOl” [ Black country saying ]
    But not wishing to show myself up I have noticed at the manly at the end of messages I see ....lol.... so come on girls and boys what’s it stand for ?
    Regards Alan
  7. #7
    Luminous Being dbroada's Avatar
    Computer Details
    dbroada's Computer Details
    Operating System:
    XP Pro
    Computer:
    Dell
    CPU:
    Intel Xeon 2.13GHz
    RAM:
    2GB
    Graphics:
    NVIDA Quadro FX 580
    Monitor:
    DELL 23" & SAMSUNG 21"
    Discipline
    Electro/Mech
    dbroada's Discipline Details
    Occupation
    Design Engineer
    Discipline
    Electro/Mech
    Using
    Electrical 2013
    Join Date
    Nov 2005
    Location
    Sussex, UK
    Posts
    5,118
    Default
    lol (often) = lot of laughs - sometimes sacastically.
    as for measurement if you MUST keep switching back a forth (as we do on a US project) decide what the units mean for you (as Alan has pointed out) and set up a dual dimensioning standards. That way you can draw a 1 unit square block and the dimensions might read 1"/25,4mm
    I think this dual dimension thing is an age thing. Us oldies have lived through both and I have no problem drawing in units (ours are set up unitless) and instinctively knowing if the are millimeters, inches, rods poles or perches, light years etc. It would appear that younge people have no concept of there being a second acceptable system. (lol)
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  8. #8
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Posts
    4,181
    Default
    Evening Dave......yeah I'm at home again and back on the forum.....
    What I was trying to point out to MSAWIN is that if he has set his drawing up for 1 drawing unit = 1 inch.......then he can't then turn around and say "I want to put a line at 45 deg for 3 ft", then type in @3<45. He has to convert the feet back to inches, and type in @36<45. I don't know of any way to get around this.....which is why I would be quite happy for you to explain to me this system of dual dimension....
  9. #9
    Computer Details
    Operating System:
    XP Pro
    Computer:
    Dell
    CPU:
    Intel Xeon 2.13GHz
    RAM:
    2GB
    Graphics:
    NVIDA Quadro FX 580
    Monitor:
    Discipline
    Electro/Mech
    Occupation
    Design Engineer
    Discipline
    Electro/Mech
    Using
    Electrical 2013
    Join Date
    Nov 2005
    Location
    Sussex, UK
    Posts
    5,118
    Default
    evening? I'm still stuck on InTools for the next few hours! At least I keep breaking it so can come back to AutoCAD while its being fixed.
    what I do is decide if I'm drawing metric or imperial - metric by choice. Then set up a dimension style with Display Alternate Units set. You will have to work out your conversion multiplier depending on your base unit. This is a mm drawing displaying imperial so the factor is 1"=25,5mm or 0,039ish.
    hopefully the attached pictures will explain more fully. The main point is - as you have already said - the drawing remains in ONE dimensioning system only.
    Dave
  10. #10
    Using
    Map 3D 2009
    Join Date
    Jun 2006
    Location
    Posts
    4,181
    Default
    Yeah, Dave......that's what I thought.....you can get around it with dimstyles. BUT, when you draw, you can only use the units you originally set up for.....be they mm, inch, mile, or as you said (and I loved that) light years.
Similar Threads
  1. A few problems please help!!
    By PD in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jul 2006, 06:35 am
  2. pan problems
    By larsonb in forum AutoCAD Drawing Management & Output
    Last Post: 15th Feb 2006, 09:40 pm
  3. ucs problems
    By john6177 in forum AutoCAD Beginners' Area
    Last Post: 26th Oct 2005, 03:00 pm
  4. MTEXT PROBLEMS
    By MuzzyLee in forum AutoCAD General
    Last Post: 6th Sep 2005, 07:56 pm
  5. Various Problems
    By highburypete in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jun 2004, 12:50 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
