Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Problems
  1. #11
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    that's it. Once you start drawing you MUST stay in that system for as long as possible unless you really don't mind constantly scaling your drawing - and keeping track of your current system.
    As I tried to say earlier I find it easy to draw in units and just visualise what those units represent but I have watched other struggle with the concept - especially the "unitless" one. If I have drawn in metric (as I prefer) and the USA insist on imperial drawings I scale every thing and change the dimstyle. Our current project has been asked for in metric but dimensioned in imperial (without metric equivalents!) so its all down to dimstyle scaling again.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  2. #12
    Senior Member brassworks's Avatar
    AutoCAD 2008
    Sep 2006
    Woburn, Massachusetts, USA
    127
    When I was working in Virginia, some counties required that civil engineering drawings be submitted in metric units. Within a year, those counties converted back to English measurements. They found that the metric measurements could never be "pure," because all of the previously designed and built stuff was in English units - the nominal inside diameter of a 24-inch RCP drain pipe, for example - and no manufacturers were making metric materials that matched the English sizes. A metric-sized pipe might be manufactured as a 500-mm nominal inside diameter. What we needed to tie real proposed drains into real existing drains was a 457-mm diameter pipe. Who's making that?
    In the meantime, the requirements became a drafting hell, since we ended up having to put text and labelling for both systems onto the plans. Talk about clutter! And who really wants to deal with a proposed utility easement across a piece of property that is 7.33 meters? It was a paltry effort to keep close to the English equivalent requirements. It failed for practical reasons, and these counties soon changed their requirements back to English.
    Personally, I only prefer the English measurements because that's what I've worked with most. But when I have had to do metric, I'm fine once I get into it. Mixing the two in a project is an abomination.
    Did you hear about the drafter who died? He couldn't draw his breath.
  3. #13
    Senior Member Bespoke's Avatar
    AutoCAD 2008
    Apr 2007
    West Midlands United Kingdom
    214
    Hi Team
    Way back in the mist of time around 1968 here in the Uk we went metric and I think it’s one of the best things that as happened in my life time calculations easy-peasy etc, etc, etc. Hence I am very pleased that I live in the part of the world that is metric. I must confess that I forget when sending drawings across the pond to the colonies to make alterations to the dim style so it contains pound shilling pence [ old money ] and metric so my clients can make sense of the drawings.
    Is it only the USA and Canada that uses old money measurements ?
    Alan
    It is said that you never to old to learn, but for someone like me who is as old as a young conker tree it takes a lot longer.
  4. #14
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    ah the good old days
    somebody I worked with back then said he went to buy some wood at the weekend.......
    "can I have some 2 x 4 please"
    "don't do inches anymore"
    "can I have some 50 x 100 then"
    "certainly, how much"
    "2 meters"
    "what's that in feet?"
    Dave
  5. #15
    AutoCAD 2008
    Apr 2007
    214
    Don’t Look Back Keep Looking Forward
    Look where you are going not where you have been
    Sod the good old days
    Alan
  6. #16
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    We turned money metric (dollars and cents) back in the mid 60's. We then turned totally metric around 1972 (I think). The problem is (in my case) that all the existing survey plans (title plans) were in the old imperial system. e.g. road reserve widths were 1 chain, or 1.5 chains, etc. Typical allotment size was 1 chain wide x 2 chains deep.
    Even today we still have to deal with imperial survey title plans, re-survey them in metric, and re-submit them to the Titles Office (in metric). Then do all the engineering design based on metric. So we still have the situation were we deal with an existing road reserve width being 1 chain...or 20.117 metres. Ideally the reserve width should be 20 metres.
    I can't see this changing for another hundred years.....so our next generation will have to understand both systems for a long time to come.
    Then there's the other survey problem that started in Australia a hundred years ago......before EDM (or total station) gear.....all the surveyors used to add 1 link for every 100 links they surveyed.....they would record a distance of 100 links, but in actual fact it was really 101 links. So we used to have to go out, re-survey the surround, then do an adjustment to get it all back to what it really is.
    Yeah...metric is great.....but it really does have some ongoing problems.
  7. #17
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,023
    I think this is heading towards Chat rather than General
    I don't think the younger (UK) children really understand imperial measurements. We are now a couple of generations into metric and fewer hear their dads talk about feet and yards. They wonder why things are based on a 2,5 and a bit cm system (for some reason schools favour a cm base) but don't understand why.
    Many years ago I was a 10 pin bowling coach. When I first started out I would take the kiddies out onto the lane saying "the lane is 40" wide and 60' long". I changed my patter after I was asked what feet and inches were.
    Dave
  8. #18
    AutoCAD 2008
    Apr 2007
    214
    Hi
    I agree this as gone into chat and may be time to finish and continue it in the chat room if members wish too.
    Alan
  1. A few problems please help!!
    By PD in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jul 2006, 06:35 am
  2. pan problems
    By larsonb in forum AutoCAD Drawing Management & Output
    Last Post: 15th Feb 2006, 09:40 pm
  3. ucs problems
    By john6177 in forum AutoCAD Beginners' Area
    Last Post: 26th Oct 2005, 03:00 pm
  4. MTEXT PROBLEMS
    By MuzzyLee in forum AutoCAD General
    Last Post: 6th Sep 2005, 07:56 pm
  5. Various Problems
    By highburypete in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jun 2004, 12:50 pm
