Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Drilled Hole
    Full Member
    AutoCAD 2004
    Mar 2007
    36
    Default Drilled Hole
    Can I draw drilled hole in Auto CAD.
    I mean is there a command in AutoCAD which can adjusts scale factor in metric holes or inches holes.
    I have been trying to design them by using Tool>Draw>Circle.
    Yours advice aare welcome on this topic
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    Have you tried using the SCALE command?
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Senior Member CromCruithne's Avatar
    AutoCAD 2007
    Jan 2007
    Miserable Mississippi
    280
    Are you looking for threaded holes or are you trying create holes that accurately depict what size drill bit would be used to drill them? I'm thinking the second, which is something you may have gotten used to in another software like Inventor. ACAD doesn't have this command however.
    -Crom
    Full Member
    AutoCAD 2004
    Mar 2007
    36
    Thank you guys on your advice
    Yes - I have used 'Scale' command when I needed to convert holes from inches to mm. But I need to know how can I use 'Scale' command to get drill bit holes.
  5. #5
    AutoCAD 2007
    Jan 2007
    280
    Could you give us an actual example of what you're trying to do. I'm not sure I completely understand. As for converting a hole from inches to mm; are trying to change the actual size of the hole, or just he way it's measured?
    -Crom
  6. #6
    Full Member
    AutoCAD 2004
    Mar 2007
    36
    Smile
    Quote Originally Posted by CromCruithne View Post
    -Crom
    Yes I am trying to create a new hole of (1/8 INCH).
    And I have to create 20 of them. So wut I have done so far is (Tools>Draw and circle) and than dimension it to (1/8 inch), which get very tedeous and complicated. I could have used array command but the holes are uneven gaps and I am not sure if there is a command on that.
    Anyways, I have to draw drill bit size hole (1/8 inch) using Auto CAD 2006.
    So wanted to know is there any comand in Auto CAD and one of the suggestion was 'Scale Command' and I did not know exactly how can I use scale command on it, hence I raised the quiry again.
    I did read the comment on Inventor but since I hadn't got an access to it, hence I thought to understand the scale suggestion.
    Hope it helps in understanding my quiry. Any further question pleae ask
  7. #7
    Senior Member RFRUSSO's Avatar
    Architectural DT 2006
    Mar 2007
    Dark side of the Moon
    285
    I personaly would draw a 1" circle and turn it into a block. Insert it and then if you need a 1/8" hole, scale it down .125 or if you need a 1/4 hole scale it down .25 and so on.
  8. #8
    AutoCAD 2007
    Jan 2007
    280
    I think you have everything you need. If you're wanting to speed things up I'd do the following:
    1. Use lines to mark every spot you need a hole
    2. Create the hole with a dimension in one of those spots
    3. Copy the hole and the dimension to the other spots.
    I think one of the things confusing me is you're calling it a drill bit hole. Do you mean something besides a hole that's exactly 1/8" in diameter?
    -Crom
  9. #9
    Full Member
    AutoCAD 2004
    Mar 2007
    36
    Well - I have designed a base plate and now I have to draw pilot holes. These pilot holes are done with a 1/8-inch drill.
    Anyways on
    -Crom
    3) Copy Holes - Can you copy multiple holes at different distance.
    What I meant was - once I have the spot for every hole and created hole for one of them and than I copy the holes to other spots by putting in different offset/ moving value from the first hole or do i need to do to it ndividually.
    Please ask if you have any further quiry.
  10. #10
    Mar 2007
    285
    If I understand what you are trying to do....
    Get your first circle in place. lets say you need to have them spaced left to right at 1", then 1.5" and finally 3" and you want to knock it out in one command. The best way I can think of is to do the following:
    at command line enter CP (copy)
    Select the center of your circle as your insertion point
    copy the circle over 1". Don't end the command yet, now hold down the shift key and right click on your mouse, a menu will pop up at your mouse pointer, select "from", now you can pick the center of the circle and copy 1.5 inches, now repeat that from thing and enter 3" and so on and so on.
  1. angled hole
    By ryan47371 in forum AutoCAD Beginners' Area
    Last Post: 19th Jan 2007, 01:33 pm
  2. Angled Hole
    By MRB64 in forum Autodesk Inventor
    Last Post: 8th Dec 2006, 12:16 am
  3. Hole Feature
    By KDB in forum Autodesk Inventor
    Last Post: 10th Sep 2005, 11:20 am
  4. Hole chart from table?
    By malpass in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jul 2005, 10:58 am
  5. CALLOUT FOR HOLE DEPTH?
    By HUGH JACKS in forum AutoCAD Beginners' Area
    Last Post: 13th May 2005, 08:37 pm
