Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,202
    Default Offset along a curve?
    Here's a problem I keep running into. Maybe there's a command to do it, but I haven't found it.
    I have a road with a centerline. I want to offset a line that is perpendicular to the centerline. No problem when the road is straight, but sometimes it curves. Is there a simple way to offset a line so that it remains perpendicular to the curve?
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Sounds like that would require a lisp routine. Also sounds like it would be a bit tricky to write.
    I just use LENGTHEN - TOTAL and click the centreline to get it to shorten to the desired chainage. Then note the coords of the endpoint, then undo to get the original centreline back, then draw a line to those coords.
    A bit of mucking around....but it works.
    Senior Member RFRUSSO's Avatar
    Architectural DT 2006
    Mar 2007
    Dark side of the Moon
    285
    When you off set from your center line, are you using the offset command or are you using the copy command? If you are using a spline to get the curves in the road and then you use the offset command it should offset to what ever value you tell it to.
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    If I understand your question...
    No simple way. And it may depend if the offset distance is also measured along the curve, or is the straight-line distance between points on the offset object. How do you do it now? My thought was to make a duplicate, then "rotate" the copy, using the "reference" option.
  5. #5
    Senior Member Norts's Avatar
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    ever tried the MEASURE command ?
    here's what i would do.
    1. turn the entity(ies) that you wish to offset into a block.
    2. trim the centreline that you wish to offset along, using the block created in step 1 as your trim line.
    3. measure along the centreline you trimmed in step 2, ensuring you click as near as possible to where you trimmed it.
    4. enter B (for block).
    5. enter name of the block you created in step 1.
    6. enter Y for Yes to the question Align with object. (This will ensure your block is perpendicular to your centre-line).
    7. enter length along your centre-line that you wish to offset.
    Hopefully, the above should give you what you desire, if my interpretation of your initial post is correct.
    Posting no more
  6. #6
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    Having read that three times, I suspect what you're trying to do is a 'polar array'
    try the array command, and select 'polar'
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Do you want to offset something at regular intervals along the centreline?
    It is quite hard to visualize what you want to do, and perhaps a picture would clarify matters
  8. #8
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,202
    All right, more detail.
    The goal is to place contours along a road. If there's an even slope, the contours cross the centerline at regular intervals. They also cross the curbs at a known offset from where they cross the centerline. I'm looking for an easier way to place contours along a curve; it's a simple Offset on a straight section.
    At present, I draw an arc of arbitrary length along the centerline from the previous point, use Lengthen to find the proper point, and draw a line to locate the contour crossings. It's clunky, but my previous methods were even clunkier. Sorry, Alan and Norts, I can't change the existing curve because it's a polyline, the road alignment.
    Yes, LDD will do it for me. When I get more confident with templates and cross sections, I'll probably do it that way. What I'm doing now is a stopgap.
    Thanks for your time and your suggestions.
  9. #9
    Map 3D 2008
    Nov 2006
    Manchester, UK
    448
    Quote Originally Posted by CyberAngel View Post
    Sorry, ... Norts, I can't change the existing curve because it's a polyline, the road alignment.
    You can always copy the road alignment and trim the copied part.
    Geez, talk about, leading a horse to water.
    If only the horse would take a drink !
    Posting no more
  10. #10
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,202
    Quote Originally Posted by Norts View Post
    You can always copy the road alignment and trim the copied part.!
    Yes, but then I'd have to explode it to get the arc I needed, and I'd have the other segments of the polyline cluttering up my drawing. I prefer not to do it that way.
    One thing I like about this forum is the professionalism. Attitude is easy to find elsewhere on the Internet. This is unnecessary.
  1. How do I do curve (arc) text?
    By Anya_N in forum AutoCAD General
    Last Post: 21st Nov 2008, 06:24 pm
  2. function curve
    By karagozm in forum AutoCAD General
    Last Post: 3rd Apr 2006, 11:30 am
  3. Intersection curve
    By jan21 in forum AutoCAD General
    Last Post: 14th Nov 2005, 07:54 pm
  4. one curve in two planes
    By inventingdreams in forum AutoCAD General
    Last Post: 15th May 2005, 11:22 am
  5. 3D Curve
    By Twilight in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jul 2003, 03:46 pm
