Results 1 to 4 of 4
    jocaan
    Default Dimension>Style or Format>Dimension Style problem
    My version is AutoCAD 2005. In using HELP to find out how to use the FIT command where you fit in a certain amount of text into boundries, I can't find the FIT tab mentioned in HELP. I just get one dialog box but there is no FIT tab.
    TIA, Frank C.
    Senior Member Kate M's Avatar
    Structural
    Revit Structure 2013
    Sep 2003
    Washington, DC
    477
    At least in 2004, you can't "fit" mtext...not sure about 2005, though
    jocaan
    Default mtext?
    I really do not know what mtext is. I used dt in the commcand box to enter my text. I have the student version of 2005 but as far as I know this version should not be incomplete and lack any tabs or options or commands that would deal with the FIT operation.
    TIA, Frak C.
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    _FIT is a standard TEXT parameter. Just type TEXT of DTEXT at the command line.
    _Justify
    _Fit
    Pick points...
    Sorry, I just don't like pull down menus. Too slow and cumbersome. -David
    R12 (Dos) - A2K
