it's your plotter drivers; anything more than that, i am sure somebody else will be along soon to be more helpful than i have been
Hi there,
I am trying to plot using a wipeout. Plot preview looks as it should be...problem comes when plotting, it seems to ignore the wipeout. I have tried toggling the frames on and off...checked if the layers were frozen etc..
Anyone any other ideas why this won't work?
thanks in advance![]()
Posting no more
managed to sort it. so for those of you who may have a similar problem.
Had to start a new drawing, then brought in each drawing as an exref, created the wipeout and adjusted the draw order for each layer.
Seemed to work in a new drawing...must be an acad glitch.![]()
So your plot has blank areas or possibly black areas that should not be there or maybe even areas that should be hidden under a wipeout are not hidden at all. To make things even more frustrating, the plot preview always looks perfect! This is a known problem in AutoCAD that relates to plotting drawings containing images (wipeouts are images). AutoCAD offers no workaround to the problem but I have found a very simple solution to the problem. Taking a clue from the always perfect plot preview I tried plotting to TIFF image files. This solved everything except the random problem of wipeouts not working. I decided to try just a single pixel white bitmap image scaled and cropped to whatever size and shape I needed and now plotting to TIFF images has completely solved the problem. I have had no problems at all using this solution for over three years now. This solution actually has some significant added benefits too. If you want to try my solution you can get the tools for it for free at http://paracadd.com Just look for ParaMASK![]()
Paraglide
http://paracadd.com
Hey guys. This sounds like a similar problem I am having
"The man who smiles when things go wrong has thought of someone to blame it on." - Robert Bloch - writer
(cont'd) - When I create a .pdf file with wipeouts the .pdf looks perfect when I bring it up on screen but when I plot the wipeouts are black. Anyone have any ideas how to fix that problem? Is it something with my plotter driver or can I fix it in Acrobat?
Using - AutoCAD 2007 & Adobe Acrobat Professional 8
thanks.
Did you try the solutions mentioned in this thread or in the Similar Threads listed below?
The solution is to not use wipeouts. After having the same problem with them previously, we don't use them anymore.
