Self intersecting usually means its overlapping somewhere or your tappered extrude hits a zero
What type of extrude are you using?
Post a screenshot of the base object and path so we can better see what its doing?
I am trying to Extrude and object but it keeps on saying "Cannot sweep or extrude a self-intersecting curve".
Here it is
Hi.....I simply exploded, then regioned again, and it extruded ok.....(dont ask why im online at 3.21 am)
Amanda....
Thanks Amanda I just need to extrude it about 2' straight so I can subtract another object from it.
That is most likely the shape of your 2d object. go through it with a fine tooth comb and make sure none of your lines overlap.
-Crom
