Results 1 to 5 of 5
Thread: Crosshair
    Senior Member johnengineer's Avatar
    AutoCAD 2007
    Mar 2007
    162
    Default Crosshair
    Is there any way to turn off the visibility of the crosshair? I understand you can control the crosshair size, but you can you turn it off?
    Senior Member
    AutoCAD 2004
    Apr 2006
    236
    ...looking into thoughts/testing theories...
    I'll hitchya back soon if I come up with anything
    Justin J. F. RamireZ - Drafter Extraordinaire
    Bryan/College Station, Tx
    REVIT MEP 2009, CAD MEP 2009, CAD LT '00 & '04, CAD 04
    Senior Member
    AutoCAD 2004
    Apr 2006
    236
    Bwong
    CURSORSIZE
    default is 5, but the range can be set from 1-99 (%)
    It doesn't seem that one could turn them 'off', per se, but you can set 'em to 1 which puts them barely outside the lines of the default apperature size. But I'm sure if you set the cursor to 1, then reset the apperature size (options), you could essentially just have an apperature floating around your screen
    Senior Member RFRUSSO's Avatar
    Architectural DT 2006
    Mar 2007
    Dark side of the Moon
    285
    I have a answer for you....
    Sorrta'
    Open "options" menu, go to the display tab, select the "colors" button use the drop down menu and select "model tab pointer" and change the color to what ever color you are using for your back ground, then do the same for your layout tab, and poof your pointer will be gone. If you want to have some sort of pointer you can also just look lower on the display tab and you will see an option for crosshairs and you can change the size there to any where from 1-100.
    Hope this answers your question
  5. #5
    Senior Member
    AutoCAD 2002
    Apr 2007
    North Carolina
    188
    When would no crosshair be desirable?
  1. Crosshair Angle?
    By PeteUK in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jan 2010, 05:36 pm
  2. Crosshair Error
    By ionica in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2006, 05:06 am
  3. Crosshair when using ordinate dimensioning?
    By Regen in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2006, 07:26 pm
  4. Crosshair problems in paperspace!!
    By LukemanVW in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2005, 11:08 am
  5. AutoCAD LT 2002 Crosshair problem
    By Meldrew in forum AutoCAD Drawing Management & Output
    Last Post: 20th Sep 2005, 11:24 am
