Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2007
    May 2007
    Karachi, Pakistan
    2
    Unhappy How to draw a Parabola?
    How do i draw a 2D parabola?
    i am a beginner, using AutoCAD2007
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    You're going to have to go back to the basics of maths here....parabolas are a bit beyond acad....but not engineering/surveying specific software. Acad civil 3d can do it.....but not isolate it.
    If you use the formula for parabolars and get hold (or write) a lisp routine you can do it.
    Having said that, I'm sure someone will be along shortly and shoot me down in flames....
    Super Member
    not specified
    Dec 2004
    YUL
    587
    Connect points equally distant from a point (focus) and a line.
    Forum Newbie
    AutoCAD 2007
    May 2007
    Karachi, Pakistan
    2
    now whats this Lisp routine?
  5. #5
    Map 3D 2009
    Jun 2006
    4,181
    Avid Idler....
    Funny you should ask that.....I was expecting it.....
    Lisp is a programing language that automates acad. There are many members here who are absolute experts with it.....and I'm sure they will be along soon to assist you.
    edit.....
    I can't help you with the formula at the moment.....I'm at home and all my survey books are at work. I'll see what happens between now and going back to work in the morning....then I can help you....
  6. #6
    Super Member
    not specified
    Dec 2004
    YUL
    587
    Quote Originally Posted by Avid Idler View Post
    This is a lisp routine to draw parabola:
    Code:
    ; draws parabola
    ; to draw parabola with given width (w) and height (h)
    ; calculate focus-vertex distance (f): f=w^2/16/h,
    ; draw parabola, trim the height, verify dimensions
    (defun c:pbl (/ f mxx x ip y cp1 cp2 p1 p2 e1 e2 osn)
      (setq osn (getvar "OSMODE"))
      (setvar "cmdecho" 0)
      (if (= ff nil)
        (setq ff 1.0)
      (princ "\n Focus to center point of parabola <distance> < ")
      (princ ff)
      (princ " > ??: ")
      (initget 2)
      (setq f (getdist))
      (if (= f nil)
        (setq f ff)
      (setq ff f)
      (if (= mxxx nil)
        (setq mxxx 2.0)
      (princ "\n Height < ")
      (princ mxxx)
      (princ " > ?? : ")
      (setq mxx (getdist))
      (if (= mxx nil)
        (setq mxx mxxx)
      (setq mxxx mxx)
      (setq mx (+ mxx f))
      (if (= x1 nil)
        (setq x1 0.1)
      (princ "\n Precision < x distance > < ")
      (princ x1)
      (princ " > ?? : ")
      (setq x (getdist))
      (if (= x nil)
        (setq x x1)
      (setq x1 x)
      (if (> x 1)
        (setq x 1)
    ; -- FIRST SEGMENT ---
      (setq ip (getpoint "\n Insert by focus: "))	; ip = focus point
      (setq y (+ f (/ (expt x 2) (* 4 f))))	; y = distance of point from base line
      (setq cp1 (polar ip (* pi 1.5) (* f 2)))
      (setq p1 (polar cp1 (* pi 0.5) f))
      (setq cp2 (polar cp1 0 x))
      (setq p2 (polar cp2 (* pi 0.5) y))
      (setvar "osmode" 0)
      (command "pline" p1 "w" 0 0 p2 "")
      (setq e1 (entlast))
      (setq xx x)
      (while (> mx y)
        (setq xx (+ xx x))
        (setq y (+ f (/ (expt xx 2) (* 4 f))))
        (setq cp2 (polar cp1 0 xx))
        (command "line" "" p2 "")
        (setq e2 (entlast))
        (command "pedit" e1 "j" e2 "" "")
      (command "mirror" e1 "" ip cp1 "")
      (command "circle" ip x)
      (setvar "osmode" osn)
    (prompt "\n type  pbl  for parabola")
  7. #7
    Senior Member
    AutoCAD 2002
    Apr 2007
    North Carolina
    188
    You also could use simple goemetry on a cone slice
  8. #8
    Forum Newbie
    AutoCAD 2010
    Jul 2011
    1
    that lisp code is pretty good.
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,510
    Another trick is put the formula into excel and calcaulate x & y values then use excel to join the x plus , plus y X,Y then in autocad do PLINE just cut & paste the x,y values from excel to the autocad command line parabola will appear.
  1. How best to draw a DPM
    By ScottWMcQ in forum AutoCAD Beginners' Area
    Last Post: 27th Feb 2007, 04:21 pm
  2. Drawing parabola
    By murrief in forum AutoCAD General
    Last Post: 20th Apr 2006, 05:23 am
  3. a question about my lisp program for ploting parabola
    By winglj in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Feb 2006, 03:23 am
  4. How to Draw 3-D
    By Gracie in forum AutoCAD Beginners' Area
    Last Post: 16th Feb 2005, 06:01 pm
  5. how to draw in 3d
    By Dan in forum AutoCAD Beginners' Area
    Last Post: 6th Dec 2002, 10:15 am
