Results 1 to 5 of 5
Thread: Layer By Color
    Forum Newbie
    AutoCAD LT 2004
    May 2007
    2
    Default Layer By Color
    I have used winTopo(www.wintopo.com) to convert a scanned image to a cad file and i have many colors that represent the different line types on the drawing. if there is a way to layer the drawing by color it would make my job 100x easier. all the data is on layer 1 but different colors. i am using AutoCAD LT 2004. Thanks soo much.
    Matt
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,071
    has LT got QSELECT? If so set up your destination layers (but keep colour white for now) and get up the properties box. Using QSELECT make a selection of all objects with a color=? Now use the property box to change their layer to your new destination. If you change their colour to "by layer" you will see which have been selected so far. When you have finished you can give each layer the colour you desire.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
    Senior Member
    AutoCAD 2007
    Aug 2006
    Arizona
    151
    Filter will also work. And is quite easy.
    Type FILTER, the dialog opens.
    Delete any filters already in the top box with the delete button, but there will probably be none the first time you use it.
    From the "Select Filter" drop down menu, select "Color". Then click the Select... button.
    Choose the color you want to filter (that is, select in your document). Once you've chosen a color, click the "Add to List" button. You will now have one color filter in the top box.
    Next click the Apply button, and it will switch back to your drawing. It is waiting for you to make a selection, so make a selection box around the ENTIRE area where you want to select by this color, the entire drawing if you like, then press space bar. You will now be left with a selection of all items filtered by that color. While they are selected, switch them to your other layer.
    Of course, you'll have to create your layers first.
    This only works if the particular entities of your drawing actually have a color set. And in filter you have to select that exact color. If the color is ByLayer or ByBlock, filter won't select it, even if it's the right color.
    Hope that helps.
    aCAD 2007 and aCAD 2002
    XP Pro Sp2, 1gb, AMD 64 X2 Dual Core 4200+ 2.2GHz
    Asus A8R32-MVP Deluxe mobo
    GeForce 8400 GS, 512mb, PCI-E
    Swap file set to 1GB
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    just for info...both qselect and filter commands are available in LT...
  5. #5
    Forum Newbie
    AutoCAD LT 2004
    May 2007
    2
    Does exactly what i want it to do! Thanks so much guys, just made my job soo much easier.
    Matt
  1. Layer Manager by Color...
    By jpsanchez19 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2007, 01:39 pm
  2. how to change a layer color in a block made out several blocks
    By firsrate_caduser in forum AutoCAD General
    Last Post: 16th Nov 2006, 06:25 pm
  3. Have Entity Name, Want Layer Color?
    By TuFoFi in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Aug 2006, 09:05 pm
  4. changing color in color control (layer )
    By ionica in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2005, 07:45 pm
