+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Feb 2007
    Posts
    50
    Default Inventor Question
    Hello, I am a newbie to Inventor LT. I created a 2-D drawing in Autocad 2007. I opened up Inventor and inserted the 2-D drawing from Autocad 2007. I was able to extrude the part. I learned that I am not able to edit the part inside Inventor. Is there a way to edit the part in Inventor that was created in AutoCAD 2007? Please advise!
  2. #2
    Senior Member jdkriek's Avatar
    Using
    Inventor 2011
    Join Date
    Mar 2007
    Location
    North Texas
    Posts
    110
    Default
    I think you need to be a little bit more specific. If I understand you right, you said you imported 2D geometry from AutoCAD to Inventor and then extruded it, correct? Did you do this in an .IPT "Part" file? It would also help if you posted that file and any error messages that you encountered, like what told you can not edit it? What exactly are you trying to edit? I don’t recommend you learn Inventor in this fashion.
    Jonathan D. Kriek
    Autodesk Applications Engineer
    Autodesk Inventor Certified Expert
  3. #3
    Senior Member
    Using
    Inventor 2008
    Join Date
    Sep 2006
    Location
    Auburn, WA
    Posts
    192
    Default
    Why can't you edit the part? When you imported the ACAD file did you select "apply geometric constraints"? When you RMB on the extrusion in the model tree, and you select edit sketch, is the entire sketch black? If not, there is no reason that you should not be able to edit the part. Can you post the file? If it is too big to post, go to www.mooload.com and post it there. Then respond with the link.
    David
  4. #4
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Feb 2007
    Posts
    50
    Default
    I apologize for the confusion. I finally figured it out. Disregard my post.
    Thanks to all who helped me on this issue.
  5. #5
    Using
    Inventor 2011
    Join Date
    Mar 2007
    Location
    North Texas
    Posts
    110
    Default
    How did you figure it out?
    It might be helpful for other readers with the same problem.
    Jonathan D. Kriek
  6. #6
    Full Member
    Using
    AutoCAD 2007
    Join Date
    Feb 2007
    Posts
    50
    Default
    Quote Originally Posted by Aardvark View Post
    I did not click on "apply geometric constraints" and it was the reason why I was not able to edit the drawing that was originally created in AutoCAD 2007.
    Therefore, after the recommendation, I imported the drawing and made sure there was a check mark next to the "Apply Geometric Constraints" and it works! THANKS AGAIN!
  7. #7
    Using
    Inventor 2011
    Join Date
    Mar 2007
    Location
    North Texas
    Posts
    110
    Default
    Glad you fixed.
    Jonathan D. Kriek
Similar Threads
  1. VBA and Inventor
    By venia in forum Autodesk Inventor
    Last Post: 6th Feb 2013, 12:53 pm
  2. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  3. Inventor LT
    By Lazer in forum Autodesk Inventor
    Last Post: 3rd May 2007, 05:30 pm
  4. Inventor - What is it ?????
    By Mr T in forum Autodesk Inventor
    Last Post: 16th Sep 2005, 08:09 am
  5. Inventor 10 to 8
    By KDB in forum Autodesk Inventor
    Last Post: 15th Sep 2005, 01:08 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
