Results 1 to 7 of 7
    Forum Newbie
    Architectural DT 2007
    May 2007
    1
    Default FATAL ERROR: Out of memory - shutting down
    I am using Autodesk Architectural Desktop 2007 on an IBM PC with a 2.39ghz P4 that has 1GB RAM and 256MB of Video memory. I have set my sweap file to 3x the amount of RAM. The error occurs when I am trying to add a layout from another file. Any suggestions?
    Senior Member borgunit's Avatar
    Mechanical 2014
    May 2007
    Ohio USA
    287
    AutoCAD crashes when ACTUAL physical memory gets down to within 100Mb. I have seen that virtual memory has no effect on it. We use 2GB of RAM and when I run some large drawing conversion programs, if it uses approx 1.85 - 1.9 gb of RAM, it will crash. We also run Unigraphics and it will run at almost 3gb of vitual memory usage. Go figure.
    AutoCAD Mechanical 2014
    WIN 7
    http://mechcad-insider.blogspot.com/
    Senior Member jdkriek's Avatar
    jdkriek's Computer Details
    Windows 7 Professional
    Multi-disciplinary
    jdkriek's Discipline Details
    Manufacturing Solutions Engineer
    Multi-disciplinary
    Inventor 2016
    Mar 2007
    North Texas
    111
    This can be caused by a number of issues. From corrupted fonts or text to major memory leaks. Can you zip and post the file?
    Jonathan D. Kriek
    KETIV Technologies, Inc.
    Autodesk Platinum Partner
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    Check Autodesk, I think they have a fix for that.
  5. #5
    Mechanical 2014
    May 2007
    Ohio USA
    287
    Are you copying the layout from clipboard or through DesignCenter?
    WIN 7
  6. #6
    Super Member Ritch7's Avatar
    AutoCAD 2016
    Jan 2008
    Norfolk, United Kingdom
    552
    hulk is correct autodesk sorted the problem i think your referring to. some time ago. il try find the link
  7. #7
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Hey, Ritch,
    You gotta start looking at the dates of old threads. Yeah, maybe you have an answer for them, but the reality, most of the participants no longer exist here.
    All you are doing is bringing old threads up to now. And confusing everyone. If it is relevant, then go for your life.
  1. Out of Memory Shutting Down...!!
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 13th Feb 2007, 12:42 pm
  2. Fatal Error
    By chance in forum AutoCAD Drawing Management & Output
    Last Post: 11th Sep 2006, 01:13 pm
  3. Out of Memory Error Message While PDF'ing
    By Mehale in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jul 2006, 09:44 pm
  4. Fatal Error: Out of memory - shutting down
    By supragod98 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jun 2006, 05:13 am
  5. fatal error: out of memory
    By gwyndion in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 1st Nov 2005, 09:28 pm
