Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
  1. #11
    Forum Newbie
    AutoCAD 2010
    May 2010
    1
    Default Lisp for important excel points into autocad
    Hello,
    Thanks for the info. But, what do I type in the command line to invoke this lisp?
  2. #12
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Try ICE
    Also you will find HERE some basics about running Lisps.
    Welcome in the forum!
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  3. #13
    Full Member
    AutoCAD 2007
    May 2010
    31
    Thank you,fuccaro,you write so cear,i learn the 'concatenate' command from your post!I cannot use Excel well!
  4. #14
    Junior Member MotoGirl's Avatar
    MotoGirl's Computer Details
    Microsoft XP
    1.93 GB of Ram
    AutoCAD 2008
    Apr 2010
    Tempe, Arizona
    16
    Quote Originally Posted by eldon View Post
    Size is no problem. I have a lisp (not available for posting) which did 10,000 points in 29 seconds.
    to bad he's not running Civil 3d, it's built for doing what your trying to do,
    i made 30,000-40,000 points in an excel file (had to be formulated) then imported them into cad with the points command. worked like a breeze.
    but i've used a lisp like the one provided to do the same thing as well, this one is better then any i've seen out there though, thanks
  5. #15
    Forum Newbie
    Civil 3D 2010
    Oct 2010
    1
    Hello All,
    I am having the same problem that SJM was having, however, the MULTIPLE POINTS command seems to be invalid, I am using autocad civil 3d 2010 version.
    Any ideas as to why this is?
    Thanks,
    JAC7707
  6. #16
    Forum Newbie
    AutoCAD 2012
    Jan 2012
    2
    Hello miguelvarez, can u please tell me how to run this lisp (Importar puntos)?
    B.R
  7. #17
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Quote Originally Posted by Mohamad View Post
    B.R
    Load the lisp as described in the link above. Then use the command iCe to run the program.
  8. #18
    Forum Newbie
    not applicable
    Dec 2011
    1
    dear sir,
    after upload i type command iCe that time error is coming(Se ha producido el error: bad argument type: variantp nil) please sir tell me the procedure for how i solve it.
    one more thing if u translate it to english , it will be very help full for me.
    i am waiting for ur reply.
    thanking u in anticipation.
    Gobinda Halder
    Doha,Qatar
    mail:gobinda_1977@rediffmail.com
  9. #19
    Full Member Mefloump's Avatar
    Mefloump's Computer Details
    Windows 7 64-bit
    Dell Latitude 6430
    Intel(R) Core(TM) i7-3540M CPU @ 3.00GHz
    4GB
    NVidia NVS 5200M
    Dual Dell P2414H (Digital)
    Mechanical
    Mefloump's Discipline Details
    Process Engineer
    Mechanical
    Inventor 2010
    Nov 2011
    Watertown, SD
    35
    I frequently use this lisp routine to create ICT fixtures from a drill file. Beats inputting each point manually. http://www.lee-mac.com/ptmanager.html
  10. #20
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    1
    will d above soln work....for generating points with text name
  1. Can I plot data from EXCEL in AutoCAD?
    By aror in forum AutoCAD General
    Last Post: 15th May 2012, 02:38 pm
  2. Good Question: AutoCAD/Excel Data Linking
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 18th Apr 2007, 05:40 pm
  3. Excel --> AutoCAD with Dynamic Data Exchange (DDE) method
    By HofCAD in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Sep 2006, 08:46 am
  4. Excel data sheets into Autocad
    By Milner in forum AutoCAD Drawing Management & Output
    Last Post: 11th Aug 2005, 05:39 pm
  5. Import Excel files to Autocad 2000
    By renuke in forum AutoCAD Drawing Management & Output
    Last Post: 9th Mar 2004, 10:53 am
